Crack in bell housing #2809393
08/16/20 08:57 AM
08/16/20 08:57 AM
Indianapolis Indiana
Jamie340 Online content OP
Jamie340  Online Content OP
I need some direction, I have a friend that is cracking the bell housing on his 904. The crack is fairly long and is close to the main body of the transmission.
Any thoughts, or suggestions?
Thank you
Jamie
Re: Crack in bell housing [Re: Jamie340] #2809433
08/16/20 10:53 AM
08/16/20 10:53 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Cut it off and put an Ultrabell on it.
Re: Crack in bell housing [Re: Jamie340] #2809435
08/16/20 11:00 AM
08/16/20 11:00 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
find out why the bell is cracking.Be sure to check the ultra bell mine was off from JW
Re: Crack in bell housing [Re: Clanton] #2809459
08/16/20 12:17 PM
08/16/20 12:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Check pump bore to crankshaft runout, next time it’s apart.
