Re: Big Block Heads
[Re: jeebis44]
#2809347
08/15/20 11:59 PM
08/15/20 11:59 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
It would be best to find out how far down the bore the piston is at TDC & then decide what head to use. Chances are you will want the smaller chamber
Re: Big Block Heads
[Re: jeebis44]
#2809455
08/16/20 12:01 PM
08/16/20 12:01 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Anyone know the chamber volume on stock 516 heads from ‘66 4bbl 383? I cc'ed a 516 head once that had hardened exhaust seats and 1.74 valves installed. I seem to recall it was 78.5 cc (NHRA Blueprint spec from the Direct Connection book was much smaller, something like 73 or 73.5 cc). You need to measure the piston deck height and the head gasket thickness. That will tell you what head cc you need for a given compression ratio... what do you have now?
Re: Big Block Heads
[Re: R/T1968R/T]
#2809730
08/17/20 12:06 PM
08/17/20 12:06 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
516 heads are approx. 84cc in factory form. 915 heads are approx. 79 ccs in factory form. you can still build a good quench motor with them. Me thinks those are Mopar furnished specs, not actual as produce sizes, I believe the 516 has smaller chambers than the one year only 915 heads had
Re: Big Block Heads
[Re: Cab_Burge]
#2809740
08/17/20 12:20 PM
08/17/20 12:20 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Questions about 516 chamber volumes always seem to generate numerous varying responses. I have cc’d a few pair of unmolested heads through the years. They were all close to 84cc. Were they all 84cc from the factory? I have no idea...... but the ones I checked were. There's no reason at all to throw pistonquench out the window and buy 84cc Edelbrock 'smog' heads. The 84 and 75 cc Ede heads are both closed chamber...... same quench using either.
Re: Big Block Heads
[Re: BigBlockMopar]
#2809742
08/17/20 12:28 PM
08/17/20 12:28 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
There's no reason at all to throw pistonquench out the window and buy 84cc Edelbrock 'smog' heads. Quench will be determined by piston depth in-the-hole and gasket thickness.
