Quick Fuel Vac secondary tuning #2809083
08/15/20 12:45 AM
08/15/20 12:45 AM
Alberta Canada
PossessedDuster Offline OP
Alberta Canada
I've been messing around the the quick fuel adjustable vac secondary I put on my 3310. From my understanding it has the purple spring inside and you allow more or less vacuum to act upon it by turning the bleed screw. I can completely turn the bleed screw in allowing full vacuum to the diaphragm and the car responds a bit better with no drivability issues. I would assume then I need a lighter spring and start over again with adjusting.
Are the Holley springs the same? No one has the Quick Fuel ones locally.
Re: Quick Fuel Vac secondary tuning [Re: PossessedDuster] #2809122
08/15/20 06:51 AM
08/15/20 06:51 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Yes, the Holley springs are the same as Quick Fuel.
Re: Quick Fuel Vac secondary tuning [Re: MadMax58] #2809124
08/15/20 06:57 AM
08/15/20 06:57 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi , after purple , you should try the holley tall yellow spring next . please post you test results . drive
