Page 2 of 4 1 2 3 4
Re: Fast car, slow ET? [Re: AndyF] #2808724
08/14/20 07:15 AM
08/14/20 07:15 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
60ft is def slow compared to E.T. Get the 60's where it should be which I'm guessing should be like high 1.2's and I think the car will preform like it should. My guess is maybe convertor. One thing I don't think that was mention is the car getting full throttle? I know some racers that cars will dip into the 9's so they slow them up to run 10.00's since they aren't certified or have their NHRA lic. By doing this they slow down their E.T. but they have good MPH for their E.T. Also I know a guy that has a car that runs consistent 5.2's in the 1/8 with ladder bar...so needing a 4 link is total BS.
Re: Fast car, slow ET? [Re: AndyF] #2808729
08/14/20 07:30 AM
08/14/20 07:30 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by AndyF
Originally Posted by B3422W5
Soft 60 foot. Car is relatively light. Good MPH
Sounds like
convertor might be knocking 60 foot out of it. Too tight?
Converter could be too tight, I don't really know how to figure that out given the info I have. He has the transbrake set at 5800 which seems like an okay number. Once I see the dyno sheets I'll have a better idea of where the torque curve is but 5800 seems like it should be in the fat part of the curve for a 540 engine. The car doesn't push thru the lights so the converter isn't super tight. I'm not sure where the stall speed is since the car doesn't have a driveshaft speed sensor. I think he shifts the car at 6600 rpm which seems a bit low for a 540 with good parts but once again, I haven't seen dyno sheets so I don't know where the power peak is. He did say the car went faster when he shifted at 6300 so maybe 6600 is a touch too high.
5800? sounds like the converter is way too loose , just from that. If this converter was too loose, it would pick up in the 60" AND MPH.
Get with a good converter company.
My deal is totally different, but my converter goes to 2900-3100 with NO chip or limiter.
What size is the converter and what company??
My buddy has a nova, 3600lbs. With a 565 it goes 9.30's at 142-144. 60' are in the 1.30 range
Heck, my sons car going low 11's 60 in the 1.40's
Almost any change I make to my car...I get the converter looked at and sometimes changed.
....BAD A$$ STREET CAR.....
Re: Fast car, slow ET? [Re: AndyF] #2808741
08/14/20 08:35 AM
08/14/20 08:35 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If nothing else I'd buy or borrow a LM2 and set it up to record rpm's. At least you could see the fall back rpm's on the shift and get an approximate rpm at the stripe to see if it's driving through the converter. Not near as much info as a Racepak can provide but a lot better than guessing. twocents
Re: Fast car, slow ET? [Re: justinp61] #2808755
08/14/20 09:12 AM
08/14/20 09:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I would've never bet my car needed a converter as loose as it is. 15-1, 572, 3300lbs, 4.30 gear, 10.5x31, 727 , 2.45 1st gear. It's been quickest with 6000-6200 fall back.
Doug
Re: Fast car, slow ET? [Re: dvw] #2808764
08/14/20 09:42 AM
08/14/20 09:42 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Are the engine build specs/details available?
CR, heads, intake, carb, header size, cam, etc?
See if the combo makes sense that it “should” be making 850hp.
Re: Fast car, slow ET? [Re: fast68plymouth] #2808799
08/14/20 10:49 AM
08/14/20 10:49 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What transmission is in it? Assume its a glide. For 140 the car should be much quicker than it is, easy 9.50's and if everything worked right 9.40's. Which makes that 60' even more horrific. A converter in a glide is a pretty critical part of the equation. I would also want to look at what shocks it has and how that ladder bar is installed. Maybe the car is just fighting itself off the line, but I would be VERY surprised if that converter was even close for the combo.
Re: Fast car, slow ET? [Re: Al_Alguire] #2808909
08/14/20 03:38 PM
08/14/20 03:38 PM
AndyF Offline OP
AndyF  Offline OP
It does have a glide in the car. I talked to the transmission builder and he said they aren't shifting the car high enough. He said the stall speed is around 6200 rpm behind that engine and they are shifting the car too low and so they are staying in the converter all the way down the track. He said to raise the shift speed to 7200 and let it fly. He also said that they had the two step set too high. He recommended setting the two step at 5300 so the converter will flash at the line. I'll pas the word on to the driver and see what happens.
Re: Fast car, slow ET? [Re: fast68plymouth] #2808911
08/14/20 03:47 PM
08/14/20 03:47 PM
AndyF Offline OP
AndyF  Offline OP
I picked up the build sheet from the engine builder. It doesn't have all the specs but it fills in a few blanks. Dart aluminum block, Dart Pro 1 heads CNC, 4.500 x 4.250, Manley 697800 pistons (should be 13:1 compression) Comp 1302B/4247B 112 solid roller with 4/7 swap. Dart intake,1250 Dominator carb. T&D 1.70 rocker arms. Peterson 5 stage dry sump. Engine builder said it made 880 hp on the dyno with a wet sump then they changed to a dry sump and it wasn't put back on dyno but he assumes it makes roughly the same.
Cam is a 4/7 swap so I want to confirm that the spark plugs wires are correct. Easy mistake to make that costs a bunch of power.
Re: Fast car, slow ET? [Re: fast68plymouth] #2808913
08/14/20 03:58 PM
08/14/20 03:58 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Here’s another thought.......
Is the cowl hood the “correct” distance from the windshield?
Attach a piece of string to the inside of the scoop, long enough to easily come out beyond the edge of the scoop.
At the top end of the track, see it the string is sticking out of the scoop.
It shouldn’t be, but if the scoop is too far away from the windshield, the inside of the scoop can be a low pressure area, instead of a high pressure area.
If the string is being sucked out of the scoop, the scoop opening is a low pressure area.
Exactly! Done this a few times before on different cars and always conclusive. This can speak to a good bit of what's missing but still there is something else major wrong if that's real the power/weight.
Re: Fast car, slow ET? [Re: Al_Alguire] #2808921
08/14/20 04:25 PM
08/14/20 04:25 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I agree with Al ! Probably a spragless too. He needs Data
Car is kinda heavy for a glide + wrong converter + wrong launch RPM + wrong shift point = PIG
"Just a Bracket car dressed up like a streetcar"
Re: Fast car, slow ET? [Re: Just-a-dart] #2808935
08/14/20 04:59 PM
08/14/20 04:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Disagree about a big inch motor in a 3000 pound car with driver being even remotely too heavy for a powerglide. I just think in this case the guy missed on the convertor and maybe, as has been pointed out, launching the car, etc
Heck they put stock glides in ultra heavy Impala’s and Caprice’s from the factory
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Fast car, slow ET? [Re: AndyF] #2808972
08/14/20 06:15 PM
08/14/20 06:15 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Not running hard enough to the 330'..... I think it needs a 400 and a different convertor.... Think it will pick up all the way around... Just my 2 cents..
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Fast car, slow ET? [Re: AndyF] #2808978
08/14/20 06:29 PM
08/14/20 06:29 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
that car is slow every where that horsepower and weight should be running easy 150 in the 1/4
Re: Fast car, slow ET? [Re: plycuda] #2808999
08/14/20 07:51 PM
08/14/20 07:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Agreed.
Re: Fast car, slow ET? [Re: fast68plymouth] #2809032
08/14/20 08:57 PM
08/14/20 08:57 PM
AndyF Offline OP
AndyF  Offline OP
Quote
Agreed.
Any thoughts on the camshaft choice? It seems "in the neighborhood" to me. Might not be perfect, but i don't think it is the problem or even part of the problem.
Re: Fast car, slow ET? [Re: AndyF] #2809151
08/15/20 09:51 AM
08/15/20 09:51 AM
So. Burlington, Vt.
So. Burlington, Vt.
Until the question about just how the converter is behaving is answered......it’s a little hard to gauge the effectiveness of the cam.
I’d say if the 60’ was noticeably worse foot braking vs the transbrake, then the cam and converter may not be on the same page.
The car performance is so far off the dyno numbers of the motor, it’s hard to know what to look at first.
But that test might be revealing.
Be nice to see a dyno sheet to see how the curve looks.
Using my 90% rule....... at 880 STP corrected HP, it should be running 10mph faster.
The 140mph is showing what works out to a 28% loss.
It hasn’t been mentioned, but I’m assuming these runs aren’t being made at a higher altitude track.
One other thing..... does the car roll easily?
No dragging brakes or trans binding up?
I guess if I had to start somewhere, I’d see about borrowing a known good carb and see if anything good came from that.
Do the footbrake vs trans brake test.
Then look at those results and see if it makes sense to try a different converter.
If after all that it was still showing way low on power, I’d have the motor tested somewhere else.
Re: Fast car, slow ET? [Re: fast68plymouth] #2809167
08/15/20 10:49 AM
08/15/20 10:49 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
On my post about the slow car of my friends, the carb we took off was the carb used to dyno it, but it sure did not work on the car at the track, & the 1st converter was WAY off. we still have a ways to go but it is MUCH better than it was
Re: Fast car, slow ET? [Re: CSK] #2809665
08/17/20 08:10 AM
08/17/20 08:10 AM
an8sec70cuda Offline
Everything is pointing to the converter being the issue IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fast car, slow ET? [Re: AndyF] #2809712
08/17/20 11:41 AM
08/17/20 11:41 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
If you could grab a video of the car launching it would tell a lot of what's going on. Data from a logger would be even better yet or just some time slips. I've seen a slow reacting transbrake play havoc on stuff like this before, worn out button or dirt in the solenoid, but you would see some inconsistent 60' and reaction times as well. Like a 1.40 on one pass and a 1.47 on the next. If it's all consistent, then the converter is wrong. A chassis dyno won't tell you what's going on at the launch
Re: Fast car, slow ET? [Re: fast68plymouth] #2812554
08/24/20 12:32 PM
08/24/20 12:32 PM
AndyF Offline OP
AndyF  Offline OP
Quote
Agreed.
Pulled the valve covers and found a broken rocker arm. Got it fixed but it hasn't been back to the track yet.
Page 2 of 4 1 2 3 4
