Page 1 of 3 1 2 3
Dakota not dead? A followup........... #2806994
08/09/20 06:49 PM
08/09/20 06:49 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
I found a space to rent to be able to work on my wagon and my Dakota almost two months ago. For almost two months of weekends, I get the truck loaded and it starts pouring rain. flame Today was no different. Today I was moving shelves I had made, and in my rush because of the rain, I forgot to check clearance between the shelves and a carport I had to pass under. Shelves were (literally) 2 inches too tall. This is the result and I wasn’t even going fast.
I’m beyond pissed right now.
John
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807002
08/09/20 07:07 PM
08/09/20 07:07 PM
Guitar Jones Offline
That sucks, sorry.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: I just killed my Dakota, I’m sick over it [Re: Guitar Jones] #2807021
08/09/20 07:55 PM
08/09/20 07:55 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Push it back out and keep going. Just watch you dont break the back glass
Re: I just killed my Dakota, I’m sick over it [Re: CYACOP] #2807024
08/09/20 08:05 PM
08/09/20 08:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree Or just leave it as is. Either way I would suggest adding a bit of urethane to what appears to be a small gap between the gasket and cab beer,
Re: I just killed my Dakota, I’m sick over it [Re: CYACOP] #2807044
08/09/20 09:01 PM
08/09/20 09:01 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
drop the headliner. get a 1" X 4" piece of lumber about 6" long and a BFH, start where the roof should be curved about 2-3" away from the center of the dent.
once you are finished fill the gap between the roof and the glass mldg with calk to prevent water leaks.
NOS HIT NOTE***don't miss the lumber with the hammer or it will go thru the glass. DAMHIK
perception is 90% of reality
Re: I just killed my Dakota, I’m sick over it [Re: TJP] #2807045
08/09/20 09:03 PM
08/09/20 09:03 PM
I can put my hand thru the gap. And the pop out windows don't seal now.
John
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807055
08/09/20 09:14 PM
08/09/20 09:14 PM
How ever fast you can get going by just putting the truck in gear (without touch the gas) in less than 50 ft, is how fast I was going.
Why I'm so mad is that I could have prevented the dent if I had got out to look when it hit.. The shelf hit, I looked in the rearview, saw the shelf was lifted a little, and put it in reverse not realizing the shelf was under the carport. Even though I barely moved back, the tension of it being caught on the carport, and the way I had it strapped down, caused it to flip forward with force.
I guess I'm better carpenter than mechanic as there is NO damage to the shelf unit, which I had built. mad
John
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807071
08/09/20 09:40 PM
08/09/20 09:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Its too bad I just cut the firewall and trans tunnel out of the 96 extended cab Dakota i have here, it was a decent cab that only needed rockers (the frame is junk, I bought the truck for the motor & trans). It does have a decent roof and all the glass is good, even has a sliding rear window. Oh well, the distance between us would kill the logic of using anything from here. Gene
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807178
08/10/20 09:32 AM
08/10/20 09:32 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
From the picture, that doesn't appear to be that bad of a fix. Even if it was just a quick one. Beat out what you can of the dent and use window urethane to fill any remaining gap. By the looks of the paint, it won't really hurt the value of the truck any. Just a couple of hours work.
Master, again and still
Re: I just killed my Dakota, I’m sick over it [Re: DaveRS23] #2807193
08/10/20 10:16 AM
08/10/20 10:16 AM
Superfreak
Superfreak
Buy a new/used truck.
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807203
08/10/20 10:44 AM
08/10/20 10:44 AM
GMP440 Offline
GMP440  Offline
A good dent wizzard guy could probably fix that.
Re: I just killed my Dakota, I’m sick over it [Re: DaveRS23] #2807205
08/10/20 10:46 AM
08/10/20 10:46 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree beer And I would use window/ windshield urethane with latex gloves as that crap gets everywhere.
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807208
08/10/20 10:54 AM
08/10/20 10:54 AM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
2 dr or 4dr I have a roof in az
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: I just killed my Dakota, I’m sick over it [Re: azmopar] #2807556
08/11/20 07:23 AM
08/11/20 07:23 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Too bad about the truck. You probably could find a similar decent used dakota for $2500 - $3000 or even less.
Re: I just killed my Dakota, I’m sick over it [Re: mopars4ever] #2807566
08/11/20 07:37 AM
08/11/20 07:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You need some boards, some buddies, and some beer to get that fixed up.
All kidding aside if you or someone can get crafty with a port a power or BFH in the right spots you can probably work it enough to get it looking decent. A friend of mine rolled his Jeep Cherokee and pushed the a pillar down and busted the windshield. He was able to get creative and push it all back enough that the door sealed and it would take a windshield again. It didn't even look very messed up in the end.
68 Barracuda Formula S 340
Re: I just killed my Dakota, I’m sick over it [Re: SattyNoCar] #2807585
08/11/20 09:28 AM
08/11/20 09:28 AM
RWG75
RWG75
I'm with ya and this was from lurching forward in my garage when should have been on stands.
Flatten both sides of the grille, bent the aftermarket driver fender.
Re: I just killed my Dakota, I’m sick over it [Re: ] #2807586
08/11/20 09:31 AM
08/11/20 09:31 AM
RWG75
RWG75
It got a good jump and put the contents of the bench in to the dining room.
Re: I just killed my Dakota, I’m sick over it [Re: mopars4ever] #2807596
08/11/20 09:56 AM
08/11/20 09:56 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You must live in a different universe than me. Those small trucks are getting IMPOSSIBLE to find in any usable condition. While there are some available for that money, they are basically clapped out.
Re: I just killed my Dakota, I’m sick over it [Re: DaveRS23] #2807625
08/11/20 11:27 AM
08/11/20 11:27 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
That roof could likely be fixed by a good metal man and smoothed out with a shrinking disc. Faster to just have a roof skin put in it maybe.
Re: I just killed my Dakota, I’m sick over it [Re: DaveRS23] #2807626
08/11/20 11:29 AM
08/11/20 11:29 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Ugh, sorry John. I think we've all been there in one way or another. It sickens us for a couple days at least, and then we figure out some kind of a solution and feel a little better. I hope you get it worked out soon. I'm not even going to go into details on the time I was pushing one of my cars out of the garage and didn't get the driver's door closed in time.
Facts are stubborn things.
Page 1 of 3 1 2 3
