I have a 1967 Belvedere gas tank problem #280526
04/07/09 05:05 PM
04/07/09 05:05 PM
Mobile Al
hemirdrnnr Offline OP
Mobile Al
I have a 1967 Belvedere and had to change the gas tank so I Bought a repo and installed it leaked around the filler tube at the tank , so I found a good original and installed it leaked in the same place. I replaced the rubber grommit both times what is the secret.
Thanks Joe
Re: I have a 1967 Belvedere gas tank problem [Re: hemirdrnnr] #280527
04/07/09 07:15 PM
04/07/09 07:15 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Is the replacement tank inlet the correct dimension? are you using hose clamps? I replaced mine last year with a good used stock mopar tank, and had no issues. It seems about as straight forward as can be, don't know where any "secrets" could hide???
Re: I have a 1967 Belvedere gas tank problem [Re: StealthWedge67] #280528
04/07/09 07:53 PM
04/07/09 07:53 PM
Mobile Al
Mobile Al
Thanks for the reply , I used a repo tank and an original it seems to be leaking around the filler tube at the tank.I did use hose clamps where the rubber elbo fits on the metal filler tube.I also used new rubber gromets each time I tried a different tank.Is the j-hook where you get the tank level or am I missing something?
Re: I have a 1967 Belvedere gas tank problem [Re: hemirdrnnr] #280529
04/07/09 08:16 PM
04/07/09 08:16 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Make sure the filler tube is clean on the outside and use grease to slide it all the way into the tank. Sometimes the crud will let gas seep by on the filler tube.
Re: I have a 1967 Belvedere gas tank problem [Re: moparpollack] #280530
04/07/09 08:27 PM
04/07/09 08:27 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Like it says above, make sure the tube is clean and smooth. I spray the tube with silicone and insert..
Re: I have a 1967 Belvedere gas tank problem [Re: Michael] #280531
04/07/09 08:41 PM
04/07/09 08:41 PM
Mobile Al
Mobile Al
Thanks for the rplies fella's I did clean the tube well and used both grease and baby oil.Any body live close to Mobile Alabama lol
Re: I have a 1967 Belvedere gas tank problem [Re: hemirdrnnr] #280532
04/07/09 08:47 PM
04/07/09 08:47 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Too much lube will often compromise a good seal between the gasket and the steel and offer the fuel a path to escape. Part of the reason they use rubber is because it seals and contours somewhat to rough uneven surfaces. Also, in case I missed something, use a new seal, the originals can get hard and quit working.
Re: I have a 1967 Belvedere gas tank problem [Re: ScottSmith_Harms] #280533
04/08/09 04:53 AM
04/08/09 04:53 AM
Mobile Al
Mobile Al
By seal do you mean the rubber grommet that fits in the mouth of the tank it's self , if so who sells a good one? I have replaced this when I Changed to a different tank , when the tank doesn't leak I can't get the bolt that holds the metal filler tube in the frame it is miss aligned.
Re: I have a 1967 Belvedere gas tank problem [Re: hemirdrnnr] #280534
04/08/09 09:09 AM
04/08/09 09:09 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, the big donut seal that fits into the tank. You are correct, if the tube is not passing through it at the designed angle it could "pry" it into a possition that causes a gap/leak.
