door panels-end water damage #2804727
08/03/20 06:56 PM
08/03/20 06:56 PM
N.Y.
sixpacksteve Offline OP
N.Y.
bought new door panels from legendary, after a year for what ever reason the new felts didn't keep water out.
so there's warpage.
What can i put on cardboard after it dries?
a gel of some sort to harden it?
anyone?
Hell Hath No Fury Like Mine
Re: door panels-end water damage [Re: sixpacksteve] #2804732
08/03/20 07:03 PM
08/03/20 07:03 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Clear coat or maybe some sport of spray on wax coating? Does your car have the clear plastic sheet between the door frame and the door panel that is supposed to help prevent that?
Re: door panels-end water damage [Re: sixpacksteve] #2804733
08/03/20 07:05 PM
08/03/20 07:05 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Did you put the plastic liners between door panel and inner door skin similar to the factory. If not, you will be fighting this issue forever.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: door panels-end water damage [Re: 70gtx440dana] #2804735
08/03/20 07:08 PM
08/03/20 07:08 PM
N.Y.
N.Y.
No i did not put plastic back, but i will when it goes back together.
Re: door panels-end water damage [Re: sixpacksteve] #2806995
08/09/20 06:52 PM
08/09/20 06:52 PM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
repaired a set fore one of my 4 doers used water proof glue and those blue paper towels soaked in the glue kinda like fiberglass
to straiten and strengthen the edges by placing weights on them wile they dried used wax paper to keep things from sticking then used a can of flex steal to cote the cardboard and plastic sheeting
Re: door panels-end water damage [Re: racerlall] #2808718
08/14/20 05:35 AM
08/14/20 05:35 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Are these the stamped cardboard ones or the vinyl covered?
I've made new backers for vinyl covered and transferred the upholstery to the new backers.
Angry white pureblood male
