Re: Angioplasty and stents
[Re: Jjs72D]
#2804211
08/02/20 01:52 PM
08/02/20 01:52 PM
Posts: 25,949 United Socialist States of Ame...
tboomer
Modern medicine is wonderful. It is almost an outpatient procedure nowadays. If you re in good heath otherwise, your chances of recovery are excellent. X2! Good luck Stumpy!
[Re: maximus]
#2804291
08/02/20 04:07 PM
08/02/20 04:07 PM
Posts: 13,601 md
mopars4ever
md
[Re: crackedback]
#2804301
08/02/20 04:27 PM
08/02/20 04:27 PM
Posts: 9,124 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
They are great until they aren't. Family member had one inserted. It collapsed about 20 minutes before discharge from hospital. They threw someone else off the table already in procedure to correct the issue in an emergency situation. Killed the lower third of heart muscle. Had the stent collapsed 20 minutes later, the outcome would have been fatal.
They can collapse and fail, it's not common, does happen.
Good luck with the procedure and hope the outcome is successful. Really Dude? Do you think that is the message Stumpy needs right now? Never heard of this happening, and my daughter who works in the operating room tells me the procedure is very well defined and safe. I don't disbelieve you, but this is probably not a great time to share this story.
[Re: stumpy]
#2804452
08/02/20 07:18 PM
08/02/20 07:18 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
I have had several done over the last 15 or so years and they have become so routine that it's less complicated that a root canal. No Kidding. The last few were done at O dark thirty (before 6:00 AM) and I was home by 4 PM. Previously they would go in through the groin which made things a little uncomfortable for a few days but no big deal. Now they typically go through the wrist and it's like I said, less traumatic than a root canal. Not a big deal, don't sweat it a bit
[Re: Belvedere1]
#2804497
08/02/20 10:49 PM
08/02/20 10:49 PM
Posts: 3,000 Long Island, NY
shakerjoe
Long Island, NY
Had stent put in 01/28 of this year, had no idea I had a problem till the stress test my pulmonologist sent me for as part of my 9/11 screening...I feel no difference from before as to after, but cardiologist said I would’ve found out in 6 months...feel fine...but now facing a hip replacement on the 14th ugh...have to stop the stent med a week before, I’m nervous about that but I’ve been cleared...I need the hip done...I’m 57 and thought I was in reasonably good shape...but Ive been through mill more than once...doc tried to go through the wrist and that didn’t work, went through groin...I was awake the whole time watching and feeling the probe, pretty cool I will say...was out the same day...haven’t slowed down heart wise, hip is another story altogether...you’ll be good👍
[Re: Ramrod39]
#2804508
08/02/20 11:27 PM
08/02/20 11:27 PM
Posts: 2,079 CA
crackedback
CA
Good luck with the procedure and hope the outcome is successful. Really Dude? Do you think that is the message Stumpy needs right now? Never heard of this happening, and my daughter who works in the operating room tells me the procedure is very well defined and safe. I don't disbelieve you, but this is probably not a great time to share this story. I guess the "it's not common", "good luck" and "hope the outcome is successful" went over your head. There are risks with any procedure and my family member happened to be one that got the short end of the stick. If you are offended by reality, OK. Hope it goes well Stumpy...
[Re: Powerflow]
#2804512
08/02/20 11:33 PM
08/02/20 11:33 PM
Posts: 16,149 Mesa, Arizona
dart4forte
Mesa, Arizona
I have had 3 in the last 10 years. Treat it like a surgery. Do exactly what the doctors tell you. If possible they can go in through your wrist. Less recovery time. If you have high BP they may keep you overnight. Took me 2 weeks to recover from the first one. The second and third one was a little better. Ask them for a sedative before the procedure. Takes the edge off. If he finds more than one blockage he may do the first one and the other later. Reason is the dye is hard on the kidneys. Hang in there.
Abe Lincoln
