B&M Transmission Pan Done
#2803153
07/31/20 04:05 AM
07/31/20 04:05 AM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Spent 3.5 hours today finishing sanding it and buffing it out. I was going to forgo the front and rear parts since it took a whole lot of Sanding with a die grinder to get into the smaller recessed parts. But did not think Gray Paint would do. Hard to get good pictures with the flash as can be seen on the rear part. The flash shows the cloth reflation and not the mirror shine like the rest. So that part looks rough but is smooth and shines just like the rest
Re: B&M Transmission Pan Done
[Re: moparx]
#2803274
07/31/20 12:42 PM
07/31/20 12:42 PM
Posts: 5,450 Michigan
oldjonny
Don't argue with me.
sure turned out great ! what are you putting it on ? A transmission I'll be here all week
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: dOrk !]
#2803395
07/31/20 06:45 PM
07/31/20 06:45 PM
340SIX
Damn PINKster ..you are one POLISHING ... How much does the polishing process retain heat in each part on the average? I do not think it makes the part retain heat more. It does get hot buffing. enough that beer explodes you have to cool it off a few times while doing a can. Some of the cans were dented so I had to dispose of them. Here is an Eddie Air Gap I polished right before I was told I had cancer. I got a great deal on it and thought I might need it to do a Fuel Injection one day. I was told do not to paint or sand so stopped. I have all clear now but doing the whole enchilada of protection on now. Before I was just chugging away at anything I saw that I had here that I thought would look cool shiny. Even the Right Angle Oil Filter Adapter Miles of Stainless Trim for others. And some fur me. 3 timing covers sanded polished and triple plated 2 oil pans, the list goes on. Chrome is cheap if they do not have to do the work. Or just plain old as the Brits say "Al_You_Min_I_Um" Looking around last week M/T valve covers I had since age 17 that used to be black.
[Re: oldjonny]
#2803425
07/31/20 07:38 PM
07/31/20 07:38 PM
Posts: 1,111 Usa
A39Coronet
Usa
sure turned out great ! what are you putting it on ? A transmission I'll be here all week Funniest thing I've read on the forum. I'd put it on my wall cause no way that should be hidden under a car.
[Re: DirectSubjection]
#2803561
08/01/20 05:35 AM
08/01/20 05:35 AM
Guitar Jones
One talented son of a ..... Should see it in person! I still hve a beer can polished he gave me Way more patience than I have. I'm blowing that stuff off with brake cleaner and bolting it back together. Beautiful work though.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
