Re: E Body Shaker with Stage VI Heads?
[Re: ChallengerVert]
#2281510
04/03/17 01:23 PM
04/03/17 01:23 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Geometry will be off the carbs will sit higher, but it could be made to work by modifying the baseplate I am sure.
#2281620
04/03/17 03:40 PM
04/03/17 03:40 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Not a good plan I don't think. With a stock height intake you would be maybe an inch too high? Pretty unlikely you will be using a stock height intake so now you'll have to deal with dropping the baseplate a number of inches and still making sure you have decent flow squeezing between the air cleaner lid and the top of the carb. Are the issues dealt with already that tag along with the Stage Vi heads themselves?
Sheldon
#2802516
07/29/20 01:18 PM
07/29/20 01:18 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks for the responses! Looks like I will have to modify the base plate The base plate is already "dropped" If you drop it much more the carb horns will be right up on the lid.
