Re: Kirkey seat mounting
[Re: Otherlane]
#280185
04/07/09 08:51 AM
04/07/09 08:51 AM
Im doing the same thing right now and like to see the way you did yours
Same thing here, looking forward to some pics
[Re: bigdad]
#280187
04/07/09 09:23 AM
04/07/09 09:23 AM
Posts: 35,137 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
then powdercoated it all red ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#280188
04/07/09 10:24 AM
04/07/09 10:24 AM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
Get the Kirkey floor seat mounts from Jegs or Summit. Kirkey PN 99204 one part number is for one pair of brackets for one seat. In ralph's car we had DMC race cars install the brackets on top of a set of NHRA approved dual locking seat tracks along with a sliding rear seat mount using Quick pins to fasten it. This way when Ralph drove ( over 6 foot tall ), the seat could be further back. When I drove, ( not quite as tall ) I could move the seat forward. Passed tech with no issues. Dennis at DMC made spacers to make the pass seat the same height at the driver's side and just bolted to the floor. On another car, he installed quick pins in the rear portion of the passenger's seat mount allowing it to tilt forward to allow access to an intercooler. www.dmcracing.com
I'm Gumby dammit!
[Re: Gumbydammit]
#280189
04/07/09 11:43 AM
04/07/09 11:43 AM
Posts: 2,287 Hamilton,Ont
72chrgrally
Hamilton,Ont
I welded tube from the rocker bar tot the trans tunnel and hust mounted the seats to them. Another option to look at. Steve
Photobucket sucks
[Re: TrxR]
#280191
04/07/09 03:59 PM
04/07/09 03:59 PM
Gumbydammit
Lost in Pooler, GA
The sliders can be found at Jegs or Summit. Jegs number 555-70225. From what I was told, in order for them to be NHRA approved, both tracks must have locking mechanisms. Some of the cheaper tracks only have a lock on one of the slides. The rear seat back mount was fabbed , but a similar piece can also be found at jegs. It is number 550-40486.
I'm Gumby dammit!
[Re: Gumbydammit]
#280198
04/07/09 08:22 PM
04/07/09 08:22 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
those kirky brackets look nice.the 1 by the trans tunnel will have to be 1" shorter for the rais in the floor.the floor is not flat so you will need 4 spacers about 3/4" thick to space up the brackets. OH YA,the seat is wider than the holes in the floor you will need to adapt to that. i bent a gox shape on a metel brake and mounted it to the floor with the seat on top.
