speedo gear #2801745
07/27/20 02:20 PM
07/27/20 02:20 PM
italy
antonellomopar Offline OP
italy
Hello
have changed the rear end in my 71 383 Cuda to 2.76 gears. Using 245 60 15 tires, I have purchased a white speedo gear with 26 teeth. But speedo is about 10% too fast. If I am driving at 120 kmh, on the GPS it is a real 110 kmh. What is the correct gear that I should use? Thank you for the help
Re: speedo gear [Re: antonellomopar] #2801764
07/27/20 02:56 PM
07/27/20 02:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
http://www.moparts.org/Tech/tech/pages/speedo.html If the speedo is off a bit then I always felt that it was around 2-3 mph per tooth. I `m sure someone here has made the calculation to answer this for sure..
Found this https://www.forabodiesonly.com/mopa...mine-speedo-gear-size-for-a-a833.413518/
Re: speedo gear [Re: antonellomopar] #2801782
07/27/20 04:20 PM
07/27/20 04:20 PM
going 110 & showing 120 would be 10.9% too high so you need 10.9% more teeth so you need 28.36 teeth. confirm the 110/120 then either 28 or 29. Just me I'd go 28 as it might save me from a speeding ticket.
Re: speedo gear [Re: antonellomopar] #2802160
07/28/20 02:47 PM
07/28/20 02:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is the odometer off the same amount? If the odometer is accurate but the speedo is off, the gear is correct and the speedo head is the problem.
My calculations show you need a 27-tooth gear.
Re: speedo gear [Re: John_Kunkel] #2802198
07/28/20 04:20 PM
07/28/20 04:20 PM
Quote
agreed
Re: speedo gear [Re: RapidRobert] #2802474
07/29/20 12:16 PM
07/29/20 12:16 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
The magnet in the speedometer loses strength over time, that's why the charts don't always work.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: speedo gear [Re: Hrtbkr] #2802616
07/29/20 06:09 PM
07/29/20 06:09 PM
italy
italy
Thank you for the advice. The speedo has about 70 thousand kilometers on it, and is in very good condition. Before I changed gears. speedo was correct.
