Re: Changing Oil Pan Gasket
[Re: dOc …]
#2800731
07/24/20 07:19 PM
07/24/20 07:19 PM
Posts: 3,916 usa
lewtot184
usa
FIRST make sure it’s leaking there ....
Then ADD a windage tray if it doesn’t have one ....
AND ... you can make that ADDING A TRAY lots easier you ever done this before WITH a windage tray?
[Re: lewtot184]
#2800814
07/24/20 10:58 PM
07/24/20 10:58 PM
Posts: 30,488 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
AND ... you can make that ADDING A TRAY lots easier you ever done this before WITH a windage tray? Yes .... several times.... but it’s TONZ EASIER if you glue(silicone) the gasket on both sides of the tray FIRST ..... AND let it set up for a couple of hours OR overnight....
[Re: dOc …]
#2800870
07/25/20 07:49 AM
07/25/20 07:49 AM
Posts: 1,862 Sault Ste. Marie, Ontario, Can...
moparmike1
Hi, Yes, this is possible. I've done it on a 1972 Road Runner with a 400. As mentioned, the center link needs to be disconnected at one point and moved out of the way, doesn't need to be removed. Here's a link to the one-piece windage tray I used: https://www.jegs.com/i/JEGS/555/502000/10002/-1Was it easy? Not completely but I've seen worse. Good luck, Mike.
[Re: moparmike1]
#2800941
07/25/20 11:29 AM
07/25/20 11:29 AM
dOc …
Florida STAYcation
Hi, Yes, this is possible. I've done it on a 1972 Road Runner with a 400. As mentioned, the center link needs to be disconnected at one point and moved out of the way, doesn't need to be removed. Here's a link to the one-piece windage tray I used: https://www.jegs.com/i/JEGS/555/502000/10002/-1Was it easy? Not completely but I've seen worse. Good luck, Mike. That’s a PLASTIC tray ?
[Re: gygeneral]
#2801031
07/25/20 03:01 PM
07/25/20 03:01 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Ok thanks evryone, I think i'm going to try it, just ordered that one piece tray. Jegs says for use with a flat pan rail like a fabricated pan would have. Here is a picture of the gasket/tray and a picture of a typical stock type stamped steel pan rail. Good luck with that. Maybe you could fill the stiffening beads in the pan rails with epoxy so that the ribs in the gasket would have something to seal against.
[Re: gygeneral]
#2801060
07/25/20 04:10 PM
07/25/20 04:10 PM
Posts: 6,324 nowhere
Sniper
nowhere
I was thinking of using that molded gasket that incorporates the windage tray. It would easier than trying to piece a tray and two gaskets. I believe those are designed to be reuseable, if so then tie each hole in the gasket to the pan using thread and install it. I will make your life so much easier.
[Re: GomangoCuda]
#2801140
07/25/20 08:18 PM
07/25/20 08:18 PM
Posts: 1,057 Ont, Canada
gygeneral
Ont, Canada
Ok thanks evryone, I think i'm going to try it, just ordered that one piece tray. Jegs says for use with a flat pan rail like a fabricated pan would have. Here is a picture of the gasket/tray and a picture of a typical stock type stamped steel pan rail. Good luck with that. Maybe you could fill the stiffening beads in the pan rails with epoxy so that the ribs in the gasket would have something to seal against. the pic of that gasket is the up side, the engine block sealing surface, I wonder what it looks like on the bottom side, where it would seal against the cover. I see your point about the stiffening beads, Summit site does not say the same as the Jegs site
[Re: gygeneral]
#2801141
07/25/20 08:25 PM
07/25/20 08:25 PM
gygeneral
Ont, Canada
Ok thanks evryone, I think i'm going to try it, just ordered that one piece tray. Jegs says for use with a flat pan rail like a fabricated pan would have. Here is a picture of the gasket/tray and a picture of a typical stock type stamped steel pan rail. Good luck with that. Maybe you could fill the stiffening beads in the pan rails with epoxy so that the ribs in the gasket would have something to seal against. the pic of that gasket is the up side, the engine block sealing surface, I wonder what it looks like on the bottom side, where it would seal against the cover. I see your point about the stiffening beads, Summit site does not say the same as the Jegs site Ok found my answer on the Mr Gasket website, it has pics of both sides and they are the same. See the info under Tech Resources at the bottom https://www.holley.com/products/accessories/oil_pans/oil_pan_accessories/parts/61100G
