door pins #280000
04/06/09 09:56 PM
04/06/09 09:56 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
any good ideas on how to drive the door hindge pins out if you dont have a torch and just beating it with a hammer and punch isnt working
Re: door pins [Re: leavitt4] #280001
04/06/09 10:01 PM
04/06/09 10:01 PM
NW IL
Biggie Offline
Biggie  Offline
NW IL
Blast it with penetrating oil alot maybe couple days in a row. Tell it who the boss is beat the crap out of it and pray it comes loose
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: door pins [Re: leavitt4] #280002
04/06/09 10:08 PM
04/06/09 10:08 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
lol will do i think i need a bigger bfh dam thing wont budge
Re: door pins [Re: leavitt4] #280003
04/06/09 10:15 PM
04/06/09 10:15 PM
NW IL
Biggie Offline
Biggie  Offline
NW IL
sometimes if you hit the area that the pin is stuck in with the hammer it might help loosen up the rust. Just need to lightly hit so you dont dent it and make it worse though
03 chrysler 300m
10 dodge charger
Re: door pins [Re: Biggie] #280004
04/06/09 10:50 PM
04/06/09 10:50 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
This may sound really bizarre, but a hot wrench and 80W90. The gear lube sucks right down in where the heat is. Stinks something awful, but usually pretty effective.
2 Demons...no, not my kids!
Re: door pins [Re: 4speeds4me] #280005
04/09/09 11:04 PM
04/09/09 11:04 PM
NW IL
Biggie Offline
Biggie  Offline
NW IL
did the pins come out
03 chrysler 300m
10 dodge charger
Re: door pins [Re: Biggie] #280006
04/09/09 11:52 PM
04/09/09 11:52 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
no but i got the doors off figured since i was doing suicide doors i just cut the darn things off lol
Re: door pins [Re: leavitt4] #280007
04/10/09 07:39 AM
04/10/09 07:39 AM
NW IL
Biggie Offline
Biggie  Offline
NW IL
See and in the end you are gonna show it who the boss is.
03 chrysler 300m
10 dodge charger
Re: door pins [Re: leavitt4] #280008
04/10/09 09:46 PM
04/10/09 09:46 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
thats rite them hinges were no match for the cut off wheel lol
Re: door pins [Re: leavitt4] #280009
04/10/09 10:02 PM
04/10/09 10:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There is a thread over on the HAMB about penetrating oils.
Seems the best was a mix of ATF and acetone.
For next time...
Re: door pins [Re: RodStRace] #280010
04/11/09 07:47 PM
04/11/09 07:47 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Or try a hinge pin removing tool.
Re: door pins [Re: In_The_Pink] #280011
04/11/09 08:47 PM
04/11/09 08:47 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
a hinge pin removing tool?
I thought was a BFH
Re: door pins [Re: bboogieart] #280012
04/11/09 10:23 PM
04/11/09 10:23 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Re: door pins [Re: rabid scott] #280013
04/12/09 10:44 PM
04/12/09 10:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, I looked. There ain't one of them in MY tool box. The bfh and heat usually work for me, but I've run into a few that had to have the pins drilled out! Gene
