Most desirable Dana 60 housing to start with ? #2799835
07/22/20 02:49 PM
07/22/20 02:49 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Decided on Dana 60, one decision done.
So which housing? It's going to be a little narrowed (mini-tub car), but not super narrow,
it will get housing ends for drum brake backing plates. 35-spline axles.
All I know is some housings have very thick and strong tubes, and some are more than three inches diameter.
Are the center housing castings much different, other than the axle tube diameter ?
I don't think I'm opposed to tubes bigger than 3", all you need is correct spring pads and U-bolts, right ?
Right now I have a Dana housing with 2 3/4-in tubes, this is free to anyone who wants it.
Re: Most desirable Dana 60 housing to start with ? [Re: hemienvy] #2799842
07/22/20 03:14 PM
07/22/20 03:14 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The center castings are very different, the light ones are cars, the small ford one you have now, mid 70s-early 80s dodge vans and pickups. If it is a heavy duty pickup or maxivan, or camper special it will have the big housing. Some later housings 90s and up have the pinion moved. Check with Cass, that s60 housing is a bargain, and makes gear setup a joy
Re: Most desirable Dana 60 housing to start with ? [Re: 4406bbl] #2799852
07/22/20 03:28 PM
07/22/20 03:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The cheapest one you can find in good shape.
Doug
Re: Most desirable Dana 60 housing to start with ? [Re: hemienvy] #2799853
07/22/20 03:28 PM
07/22/20 03:28 PM
an8sec70cuda Offline
Pretty sure the car housings had 3" tubes and truck housings have 3.125" tubes...or is it 3.25"? I'd have to crawl under one of mine to measure. Tube diameter isn't a big deal...got my U bolts from NAPA.
There are 2 different housings...the standard Dana 60 and the Dana 60 HD. The HD is heavier and has an extra strengthening rib across the top of the housing.
The HD is fine to use, just a little heavier. Some prefer it b/c it also has thicker tubes too IIRC.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Most desirable Dana 60 housing to start with ? [Re: dvw] #2799856
07/22/20 03:33 PM
07/22/20 03:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Doug
This! /\
'63 Dodge 330
11.19 @ 121 mph
Re: Most desirable Dana 60 housing to start with ? [Re: an8sec70cuda] #2799938
07/22/20 06:28 PM
07/22/20 06:28 PM
Actually Dana made at least 4 different Dana 60 housing with different axle tube O.D. starting at 2.5 O.D used in some front wheel drive 4x4 pickups, 2 3/4,3.0, 3.125 and 3.250 axle tubes That i have seen or heard of(I hadn't heard of the 2 3/4 O.D. housing until this post shock)
I have owned and used the other ones up
Re: Most desirable Dana 60 housing to start with ? [Re: Cab_Burge] #2799944
07/22/20 06:48 PM
07/22/20 06:48 PM
Superfreak
Superfreak
I have one out of 9 passenger van with the bigger tubes but they are machined down to 3" from factory to fit into the housing.
Re: Most desirable Dana 60 housing to start with ? [Re: ] #2800023
07/22/20 10:39 PM
07/22/20 10:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
People with good Dana's want an arm and a leg ... and then you're going to cut it up. save yourself a lot of hassle and probably some $$ and just buy and aftermarket unit built to your specs.
Re: Most desirable Dana 60 housing to start with ? [Re: Stanton] #2800036
07/22/20 11:20 PM
07/22/20 11:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree If you can do all the work yourself then go ahead with an old truck housing, but it will be about the same money in the long run to start off with a Strange S60 housing cut to length.
I would do a 9" if I was starting with a clean sheet twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Most desirable Dana 60 housing to start with ? [Re: fourgearsavoy] #2800077
07/23/20 06:03 AM
07/23/20 06:03 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
S60 brand new
Re: Most desirable Dana 60 housing to start with ? [Re: hemienvy] #2800100
07/23/20 08:32 AM
07/23/20 08:32 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd figure out how long it needed to be axle flange to flange then call Strange and see what a housing and axles would cost.
Re: Most desirable Dana 60 housing to start with ? [Re: hemienvy] #2800232
07/23/20 02:08 PM
07/23/20 02:08 PM
AndyF Offline
AndyF  Offline
Do you have all the tools necessary for working on a Dana 60? If not then you might want to buy the S60 housing now. The case spreader and related tools can add up to a few hundred dollars.
Re: Most desirable Dana 60 housing to start with ? [Re: AndyF] #2800257
07/23/20 02:55 PM
07/23/20 02:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Funny you said spreader, when I worked for Dodge they said the case should only be spread twice after that get a new case. Personally I’ve never used one since, 50 years, pry em out with a big bar then hammer em back in. Not sure if any of the hundred or so I’ve done had a problem though. I’ve still got 1 car and 2 truck housings but I’m seriously looking at the S60 housing ($499 i think) no ends and $600 or so with the ends. I like the idea of bearing adjusters, and throw all those shims away.
Re: Most desirable Dana 60 housing to start with ? [Re: cudaman1969] #2800272
07/23/20 03:16 PM
07/23/20 03:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've never used a spreader either. Dial indicator, mic, slip on side bearings, torque wrench. Spool, gear, bearings,axles, studs less than $1K. Heck Dizuster turbo car still has the Junkyard gears.
Doug
Re: Most desirable Dana 60 housing to start with ? [Re: dvw] #2800282
07/23/20 03:37 PM
07/23/20 03:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Doug
Mine still has the junkyard gears AND bearings. grin Race shop said they looked okay so off we went! Installed Dr. Diff Spool, axles and bearings and used 8 3/4 ends cut down on the lathe.
'63 Dodge 330
11.19 @ 121 mph
Re: Most desirable Dana 60 housing to start with ? [Re: GY3] #2800315
07/23/20 05:19 PM
07/23/20 05:19 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Ya can still bust 'em if you try grin
Re: Most desirable Dana 60 housing to start with ? [Re: cudaman1969] #2800342
07/23/20 06:19 PM
07/23/20 06:19 PM
iagree Me too on the spreader, never used one. I shoot for .013 preload on the carrier bearings and use a rubber mallet to carefully install the carriers or spool up hammer grin Works good, last a long time scope
Re: Most desirable Dana 60 housing to start with ? [Re: Cab_Burge] #2800462
07/24/20 01:15 AM
07/24/20 01:15 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Most desirable D60 case is an S60
Re: Most desirable Dana 60 housing to start with ? [Re: J_BODY] #2800583
07/24/20 11:28 AM
07/24/20 11:28 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Pricing is right here with most options shown:
https://www.strangeengineering.net/strange-s60-dana-60-rear-ends/
Around here a core full floater axle is usually about 200.
If you know someone...., maybe even free (I don't know anyone).
It'll need clean up, teardown, ends cut off.
On top of that It'll probably be rusty/something else to deal with.
A brand new S60 case with new tubes, the side adjusters, the hoopla/proprietary whiz bang space age materials, and very importantly: no rust to monkey with
is only 575, if the prices on their website are still correct.
For the difference in price I have to ask myself "what is my time worth?"
shruggy
Rich H.
Esse Quam Videri
Re: Most desirable Dana 60 housing to start with ? [Re: Cab_Burge] #2800592
07/24/20 11:44 AM
07/24/20 11:44 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I use a heavy brass hammer, inboard boat driveshafts work great for making hammers, the two I have are 1.5” also have a monelL one
