Re: Most desirable Dana 60 housing to start with ?
[Re: hemienvy]
#2799853
07/22/20 03:28 PM
07/22/20 03:28 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Pretty sure the car housings had 3" tubes and truck housings have 3.125" tubes...or is it 3.25"? I'd have to crawl under one of mine to measure. Tube diameter isn't a big deal...got my U bolts from NAPA.
There are 2 different housings...the standard Dana 60 and the Dana 60 HD. The HD is heavier and has an extra strengthening rib across the top of the housing. The HD is fine to use, just a little heavier. Some prefer it b/c it also has thicker tubes too IIRC.
[Re: dvw]
#2799856
07/22/20 03:33 PM
07/22/20 03:33 PM
Posts: 4,672 Wichita
GY3
Wichita
The cheapest one you can find in good shape. Doug This! /\
[Re: an8sec70cuda]
#2799938
07/22/20 06:28 PM
07/22/20 06:28 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
There are 2 different housings...the standard Dana 60 and the Dana 60 HD. The HD is heavier and has an extra strengthening rib across the top of the housing. The HD is fine to use, just a little heavier. Some prefer it b/c it also has thicker tubes too IIRC. Actually Dana made at least 4 different Dana 60 housing with different axle tube O.D. starting at 2.5 O.D used in some front wheel drive 4x4 pickups, 2 3/4,3.0, 3.125 and 3.250 axle tubes That i have seen or heard of(I hadn't heard of the 2 3/4 O.D. housing until this post ) I have owned and used the other ones
[Re: Cab_Burge]
#2799944
07/22/20 06:48 PM
07/22/20 06:48 PM
Superfreak
Superfreak
I have one out of 9 passenger van with the bigger tubes but they are machined down to 3" from factory to fit into the housing.
[Re: Stanton]
#2800036
07/22/20 11:20 PM
07/22/20 11:20 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
People with good Dana's want an arm and a leg ... and then you're going to cut it up. save yourself a lot of hassle and probably some $$ and just buy and aftermarket unit built to your specs. If you can do all the work yourself then go ahead with an old truck housing, but it will be about the same money in the long run to start off with a Strange S60 housing cut to length. I would do a 9" if I was starting with a clean sheet Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2800257
07/23/20 02:55 PM
07/23/20 02:55 PM
Posts: 8,249 fredericksburg,va
cudaman1969
fredericksburg,va
Do you have all the tools necessary for working on a Dana 60? If not then you might want to buy the S60 housing now. The case spreader and related tools can add up to a few hundred dollars. Funny you said spreader, when I worked for Dodge they said the case should only be spread twice after that get a new case. Personally I’ve never used one since, 50 years, pry em out with a big bar then hammer em back in. Not sure if any of the hundred or so I’ve done had a problem though. I’ve still got 1 car and 2 truck housings but I’m seriously looking at the S60 housing ($499 i think) no ends and $600 or so with the ends. I like the idea of bearing adjusters, and throw all those shims away.
[Re: cudaman1969]
#2800272
07/23/20 03:16 PM
07/23/20 03:16 PM
Posts: 9,835 MI, usa
dvw
MI, usa
I've never used a spreader either. Dial indicator, mic, slip on side bearings, torque wrench. Spool, gear, bearings,axles, studs less than $1K. Heck Dizuster turbo car still has the Junkyard gears. Doug
[Re: dvw]
#2800282
07/23/20 03:37 PM
07/23/20 03:37 PM
GY3
Wichita
I've never used a spreader either. Dial indicator, mic, slip on side bearings, torque wrench. Spool, gear, bearings,axles, studs less than $1K. Heck Dizuster turbo car still has the Junkyard gears. Doug Mine still has the junkyard gears AND bearings. Race shop said they looked okay so off we went! Installed Dr. Diff Spool, axles and bearings and used 8 3/4 ends cut down on the lathe.
[Re: GY3]
#2800315
07/23/20 05:19 PM
07/23/20 05:19 PM
Posts: 2,916 A shed in England
Tig
A shed in England
Ya can still bust 'em if you try
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: J_BODY]
#2800583
07/24/20 11:28 AM
07/24/20 11:28 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Pricing is right here with most options shown: https://www.strangeengineering.net/strange-s60-dana-60-rear-ends/Around here a core full floater axle is usually about 200. If you know someone...., maybe even free (I don't know anyone). It'll need clean up, teardown, ends cut off. On top of that It'll probably be rusty/something else to deal with. A brand new S60 case with new tubes, the side adjusters, the hoopla/proprietary whiz bang space age materials, and very importantly: no rust to monkey with is only 575, if the prices on their website are still correct. For the difference in price I have to ask myself "what is my time worth?"
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2800906
07/25/20 10:08 AM
07/25/20 10:08 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Pricing is right here with most options shown: https://www.strangeengineering.net/strange-s60-dana-60-rear-ends/Around here a core full floater axle is usually about 200. If you know someone...., maybe even free (I don't know anyone). It'll need clean up, teardown, ends cut off. On top of that It'll probably be rusty/something else to deal with. A brand new S60 case with new tubes, the side adjusters, the hoopla/proprietary whiz bang space age materials, and very importantly: no rust to monkey with is only 575, if the prices on their website are still correct. For the difference in price I have to ask myself "what is my time worth?" This is the first time that I have seen a Mopar part be cheaper than a similar GM version. (Pinion snubber version vs the various GM) I am a stubborn, cheap [censored] and love doing stuff myself but I think this is one place I would go with the aftermarket Strange over the junkyard deal. By the time I make/buy the fixtures to do a proper narrowing job, I'll be way ahead with the S60
[Re: gzig5]
#2802835
07/30/20 11:43 AM
07/30/20 11:43 AM
ZIPPY
S.E. Michigan
Pricing is right here with most options shown: https://www.strangeengineering.net/strange-s60-dana-60-rear-ends/Around here a core full floater axle is usually about 200. If you know someone...., maybe even free (I don't know anyone). It'll need clean up, teardown, ends cut off. On top of that It'll probably be rusty/something else to deal with. A brand new S60 case with new tubes, the side adjusters, the hoopla/proprietary whiz bang space age materials, and very importantly: no rust to monkey with is only 575, if the prices on their website are still correct. For the difference in price I have to ask myself "what is my time worth?" This is the first time that I have seen a Mopar part be cheaper than a similar GM version. (Pinion snubber version vs the various GM) I am a stubborn, cheap [censored] and love doing stuff myself but I think this is one place I would go with the aftermarket Strange over the junkyard deal. By the time I make/buy the fixtures to do a proper narrowing job, I'll be way ahead with the S60 Sometimes I post things and wonder if anyone reads them, so thanks for the reply. Same situation here.
Rich H.
Esse Quam Videri
[Re: hemienvy]
#2802943
07/30/20 03:03 PM
07/30/20 03:03 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
I pulled mine out of a 1982 F-250 and got it for $100. Reused the 3.54 gears, bought everything else from Cass and had a local shop chop it down, put new perches on and assemble. With the Explorer disc brakes I think I had $2400 into it. It must have 3" tubes since the u-bolts fit over it.
