Re: Problems with Poly 318- Bogs, Backfires ect.
[Re: 65dodgebob]
#279904
04/06/09 09:47 PM
04/06/09 09:47 PM
RapidRobert
I'd open up that carb & at the very least check the float level & also plug wires/vacuum leak
[Re: Radio Joe]
#279911
04/07/09 03:23 PM
04/07/09 03:23 PM
RapidRobert
its not from too large of accellerator pump shot. Joe keep searching & inform us when you discover it.
[Re: Radio Joe]
#279913
04/07/09 06:49 PM
04/07/09 06:49 PM
Posts: 1,021 Chesapeake Va
BobK
Chesapeake Va
How old is the gas in the tank? My poly did similar when I changed over to electronic ignition. I disconnected the vacuum advance and the problem went away.
1964 Plymouth Fury x 2 1964 Plymouth Sport Fury
[Re: Radio Joe]
#279916
04/07/09 08:17 PM
04/07/09 08:17 PM
RapidRobert
what do the plugs look like when you R&R'd them? Do you have another carb handy you could sub in real quick to try & narrow this down? Will it rev to 3K OK by opening the throttle by hand but has a problem hitting 3K on the road?
[Re: RapidRobert]
#279917
04/07/09 09:50 PM
04/07/09 09:50 PM
Posts: 90 Laurens, SC
Radio Joe
Laurens, SC
3,5,2 and 8 are all very black and sooty
1,7,4 and 6 have a little soot on them but are mostly orange.
I do not have another carb to swap on. Wish I did. My stock Stromberg I had accellerator pump issues with even after rebuild so I switched to the holley.
If the car is in park and I rev it, it seems to rev good. if I goose it wide open really fast there is some hesitation at first.
On the street it takes a while to get to 3K (I am guessing at 3K as none of my guages are hooked up). Atleast alot slower than I think it should. I do realize that a heavy 66 Fury 4 door isnt going to be a racecar with a stock 318 in it but there is definitely something wrong.
Maybe I can get a video to show you and upload it to youtube.
[Re: ph23vo]
#279918
04/07/09 09:52 PM
04/07/09 09:52 PM
Radio Joe
Laurens, SC
get rid of the points first.. use pertronix or MP kit.. then start over good luck dan
Wish I could- that is a change for a later day when I have more $$$$
While I understand ignition could be a factor, I need to narrow it down to that before I can justify spending on the new ignition.
