Re: 2011 Jeep failed emissions - Cam Position Sensor code
[Re: Dcuda69]
#2797763
07/17/20 09:46 AM
07/17/20 09:46 AM
Posts: 1,411 Central Pa
moparjim79
Central Pa
Agree^^ Worst case is a t-chain but that normally sets a cam/crank correlation code.Throw a CMP sensor at it and hope for the best. Good luck!! Just to clarify, is it a 2001, or a 2011 like the title reads? If it's a 2011 with the 5.7, yes, very good chance the timing chain asm. will need replaced, but the easiest thing to do is toss a sensor at it if you dont have access to a scope( sounds like you do not)
[Re: moparjim79]
#2798088
07/17/20 09:56 PM
07/17/20 09:56 PM
Posts: 9,142 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Agree^^ Worst case is a t-chain but that normally sets a cam/crank correlation code.Throw a CMP sensor at it and hope for the best. Good luck!! Just to clarify, is it a 2001, or a 2011 like the title reads? If it's a 2011 with the 5.7, yes, very good chance the timing chain asm. will need replaced, but the easiest thing to do is toss a sensor at it if you dont have access to a scope( sounds like you do not) Well crap. it is a 2011. My typo.
