Re: Fuel Injection for a 340
[Re: AndyF]
#2797624
07/16/20 09:34 PM
07/16/20 09:34 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Holley Sniper with a Hyperspark distributor will be the easiest EFI kit to install. I doubt that anyone makes an EFI gas tank for a late model RR so he'll most likely need to have something fabricated or else use an external fuel pump. Andy - and you didn't reference me??? I'm hurt Anyway, 65pacecar, I can take care of you. Go to fastmanefi.com
[Re: 65pacecar]
#2797678
07/16/20 11:19 PM
07/16/20 11:19 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
I work with a guy that has a nice 73 RR 340 Automatic car and he is interested in installing fuel injection to replace the Edlebrock Carb and make it more drive-able. Any suggestions on a good plug and play kit for the system? Mild street driven car so he doesn't want to go crazy on it but make it more enjoyable to drive on today's "gas". 360 Magnum with full electronics and overdrive transmission for about 1/3 the cost and zero headaches of an aftermarket FI from the local autowrecker. 10 times the reliability, and 30 to 40 percent better fuel mileage. Tell him I said "you're welcome". Better yet: 5.7, 6.1 or 6.4 Hemis.........but that's a seperate topic.
Mo' Farts
Moderated by "tbagger".
[Re: Mopar_Rich]
#2797729
07/17/20 08:29 AM
07/17/20 08:29 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I've installed 4 Holley Snipers now, 1 being on my 440/512 stroker with the dual sync timing control. By far the best mod I've ever done to my car. My other 3 customers are also elated with their choice. Make sure to get the EFI ready fuel tank as it makes things clean and easy for installation.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: Dragula]
#2798469
07/18/20 10:45 PM
07/18/20 10:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The Sniper is the easiest to set up.. I went with the HP unit to make more power, I was gonna run HP on my 416 in my Rampage for DW but I changed my mine and use the Rampage as my street rod that I drive alot
[Re: Mopar_Rich]
#2802158
07/28/20 02:45 PM
07/28/20 02:45 PM
Posts: 6,713 KY
65pacecar
KY
Thanks again for all the replies and information. Rich, he may be giving you a call in the near future as he decides what he wants to do with his setup. https://www.fastmanefi.com/
[Re: 65pacecar]
#2802201
07/28/20 04:24 PM
07/28/20 04:24 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I'm a Megasquirt EFI guy but if I were to buy a throttle body system it would for sure be Holley from Rich.
68 Barracuda Formula S 340
