8.75 Narrowed, Random thought
#2797402
07/16/20 01:03 PM
07/16/20 01:03 PM
Posts: 22,696 Bitopia
jcc
Bitopia
So this has little to do with the other current 8.75" narrow rear end thread, but got me thinking. I'm wondering, does a narrowed 8.75 give the center section a tougher time in high HP applications, in that the narrower the rear, the less "spring/twist" in the axles, and I have never heard this as a strength criteria mentioned when we have the monthly threads on the safe power range for an 8.75"? So we should now include narrowness of the rear in the discussion regarding car weight, tire size/width/compound, gearing, application, back brace, billet caps, etc?
Re: 8.75 Narrowed, Random thought
[Re: jcc]
#2797488
07/16/20 03:44 PM
07/16/20 03:44 PM
Posts: 4,209 New York
polyspheric
New York
I agree, the torsional distortion is a shock absorber, but how much? Would reducing the diameter mid way allow more rotation? Bill Jenkins remarked on the 12 bolt 50 years ago that he painted a stripe along the axle, and it was safe to use until the stripe went half-way around. !!!!
Boffin Emeritus
[Re: cudaman1969]
#2797515
07/16/20 05:02 PM
07/16/20 05:02 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
I've broken two stock A body 8 3/4 axles, both broke after twisting less than 3 splines I advice a friend who had a set of the early Mark Williams 30 spline axles and spool in his 1971 Demon two rotate the left side twisted axles to the passenger side to untwist it It broke, shattered between the twist in the splines and the bearing end, it was a really ugly break , after about three time trails runs. He called Mark Williams and they told him to NEVER swap axles from side to side on any rear end He ended up buying a set of Yukon race axles instead of buying some of the better American made brands
[Re: jcc]
#2797546
07/16/20 07:21 PM
07/16/20 07:21 PM
Posts: 5,894 Florida
Locomotion
If longer axles actually increases their torsional twist, wouldn't that promote the amount and rate of twist that takes a "set" and eventually leads to breakage?
I'm thinking along the lines of bending a wire back & forth until it eventually breaks. It's easier to bend a long wire so it will heat up faster and break sooner. The shorter wire has the same diameter, but despite the same force being used, it's harder to bend and creates less heat and fatigue. It seems that something will last longer the less it bends/twists.
But I agree with a previous post.....the 8 3/4" has other weak spots, especially the ring & pinion teeth. So anything made stronger in the "chain" of parts will reveal the weakest "link" sooner.
I also read that it's a bad idea to swap axles side to side. Same applies to torsion bars.
[Re: jcc]
#2797661
07/16/20 10:33 PM
07/16/20 10:33 PM
Posts: 4,682 On the parachute mount
n20mstr
So this has little to do with the other current 8.75" narrow rear end thread, but got me thinking. I'm wondering, does a narrowed 8.75 give the center section a tougher time in high HP applications, in that the narrower the rear, the less "spring/twist" in the axles, and I have never heard this as a strength criteria mentioned when we have the monthly threads on the safe power range for an 8.75"? So we should now include narrowness of the rear in the discussion regarding car weight, tire size/width/compound, gearing, application, back brace, billet caps, etc? Why narrow a weak rear ? Lol Any thing with decent power will destroy an 83/4 just because of housing flex alone . What’s next ? Pinion angle ? ! Lmao
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2797690
07/17/20 12:16 AM
07/17/20 12:16 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
When an 8-3/4 center section breaks, I believe a lot of it has to do with the housing flexing which then allows the axles to essentially act as pry bars to distort everything in the case. The shorter the housing is, the less leverage the ends have on the center section, effectively strengthening the overall package. (My theory).
After breaking a relatively stock setup a couple of times, I finally backbraced the housing, installed an MW steel cap, and went with a 35-spline spool and axles. It’s still the stock length, and I’ve been beating on it for a number of years now with no issues.
[Re: StealthWedge67]
#2797742
07/17/20 09:11 AM
07/17/20 09:11 AM
jcc
Bitopia
Maybe my concern was not clear enough. It does not center (pun) around axle strength or breakage, its more about the hit, or lack of an axle shock absorber effect a shorter axle has, on what many consider already a "weak" 8.75, meaning the possibility a narrower housing has inducing greater shock loads on the CENTER section than a longer axled set-up.
[Re: tabletop390]
#2798238
07/18/20 11:10 AM
07/18/20 11:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
90% of the rears that I use are 8 3/4 but I also have a 9" in my Rampage.. on the race car it is shortened and I have used ladder bars and a 4 link.. large dia axles on all of them I put a line on them the full length to measure twist.. the biggest issue has always been that the axles will twist at the splines.. I have seen it on axles as new as 1 week old and determined that they take a set right away and tend to stay there.. I back brace right to the end of the housing.. if you look at a stock housing with leafs you will see that the housing bends at the outer edge of the leafs(thus the brace on mine going full length of the housing).. I have only broke 1 8 3/4 of all the years racing and I leave very hard 1.19 60
