MODIFY SB TIMING COVER FOR -AN #2796843
07/15/20 09:19 AM
07/15/20 09:19 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Anyone modify the factory timing chain cover to eliminate the water pump? Instead of redoing the rad support, I thought about installing a 3 row rad in my early A and use a remote water pump with either -AN or barb type connectors. Fill in the cooling ports on the timing cover with the fittings and match the lines with the new rad. Simpler way?
Re: MODIFY SB TIMING COVER FOR -AN [Re: A/MP] #2796845
07/15/20 09:27 AM
07/15/20 09:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have thought about the same thing with my small block as well. I thought about just having the fittings welded to the Meziere back plate, that would eliminate the need of a special timing cover and could be moved to other engines easier. I just haven't wanted to pony up the money for a new water pump.
68 Barracuda Formula S 340
Re: MODIFY SB TIMING COVER FOR -AN [Re: Bad340fish] #2796864
07/15/20 10:35 AM
07/15/20 10:35 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I tapped my CPI back cover and screwed in -12 fittings. Those lines to remote CPI pump and a -16 from pump to radiator. Welded -16 fitting to radiator.
Re: MODIFY SB TIMING COVER FOR -AN [Re: A/MP] #2796898
07/15/20 11:42 AM
07/15/20 11:42 AM
AndyF Offline
AndyF  Offline
Something like this?
Re: MODIFY SB TIMING COVER FOR -AN [Re: AndyF] #2796975
07/15/20 01:33 PM
07/15/20 01:33 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
That is really nice, i don't think i have seen a remote water pump
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: MODIFY SB TIMING COVER FOR -AN [Re: 65signet] #2796984
07/15/20 01:54 PM
07/15/20 01:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Andy do you still have any of those covers floating around?
65Signet, Meziere makes some nice remote mount pumps, can even be mounted to a radiator.
https://www.meziere.com/Products/Cooling-System-Products/Pumps-Electric/Remote-Mount.aspx
Re: MODIFY SB TIMING COVER FOR -AN [Re: Bad340fish] #2797041
07/15/20 03:21 PM
07/15/20 03:21 PM
AndyF Offline
AndyF  Offline
Yeah, the remote pumps that bolt on to the lower port of the radiator are really slick. Frees up space on the engine and Meziere says they last longer since they don't have to deal with the heat and vibration of the engine. I originally designed set ups for both BB and SB Mopar engines to use remote pumps but found that not very many people want to use them so I stopped making that stuff. I thought it was cool but I guess I was out in left field.
Re: MODIFY SB TIMING COVER FOR -AN [Re: AndyF] #2797046
07/15/20 03:30 PM
07/15/20 03:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Why not just use the billet Moroso bolt in stock location Electricwater Pump. Puts out plenty of water, street or strip. Have used it on various A body’s for 20 years
The fittings are clockable
Brother runs one in his 66 Dart.
Yet to see a fan/ radiator clearance issue using this pump. Lots of options to make it fit.
https://www.jegs.com/i/Moroso/710/63565/10002/-1
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: MODIFY SB TIMING COVER FOR -AN [Re: B3422W5] #2797069
07/15/20 04:28 PM
07/15/20 04:28 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we can mod the cover to use an fittings if thats what you want to do. i'd have to look at the hole sizes but pretty sure you can get a 1" npt or a fairly large oring fitting in there.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: MODIFY SB TIMING COVER FOR -AN [Re: Jerry] #2797233
07/15/20 11:32 PM
07/15/20 11:32 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I use a Maziere remote pump and plumb it directly into the center core plugs in the block.
The motor plate seals the block off at the coolant ports from the timing cover.
I forget who I got the core plugs from , but they were about 1/2 " thick aluminum and tapped for 3/4 NPT to -12 AN fittings.
It works pretty well.
Re: MODIFY SB TIMING COVER FOR -AN [Re: tubtar] #2797297
07/16/20 09:24 AM
07/16/20 09:24 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Take the adapter legs off your elect pump tap holes, instant remote pump. Just find a place to bolt it down. I bolted mine to motor plate.
Re: MODIFY SB TIMING COVER FOR -AN [Re: A/MP] #2797305
07/16/20 09:48 AM
07/16/20 09:48 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
If your running into an issue with the water pump being too long there are a couple of options, this is what some people do when swapping a 318/360 into an old dodge power wagon that was originally a flathead 6 cylinder. They either run the 61-68 cast iron water pump (the outlet is on the opposite side compared to the aluminum one) that is .700" shorter than the later 69 and newer aluminum pump, or they have the aluminum housing cut down and shorten the shaft to make them fit. http://www.uglytruckling.com/pw_v8_kit.html
Just thought this might be another option.
Re: MODIFY SB TIMING COVER FOR -AN [Re: AndyF] #2797363
07/16/20 11:55 AM
07/16/20 11:55 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
[quote=A/MP]Anyone modify the factory timing chain cover to eliminate the water pump? Instead of redoing the rad support, I thought about installing a 3 row rad in my early A and use a remote water pump with either -AN or barb type connectors. Fill in the cooling ports on the timing cover with the fittings and match the lines with the new rad. Simpler way?
I thought that I saw something like that with a Jessel belt drive. Thought it was a Jessel products.
Re: MODIFY SB TIMING COVER FOR -AN [Re: A/MP] #2797441
07/16/20 02:08 PM
07/16/20 02:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a plate with a "Y" tube on it that has a -12 fitting on it. I can't remember who made it. It was with the Daytona when I bought it. There was also a remote pump that looked kinda like a Holley fuel pump.
Re: MODIFY SB TIMING COVER FOR -AN [Re: slantzilla] #2797701
07/17/20 02:52 AM
07/17/20 02:52 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
A plate with two fittings in place of the water pump is probably the simplest set up I have seen. Otherwise, as have been suggested, you can go the route of freeze plugs with AN fittings and plumb it up that way.
Not sure if these are available readily over there, but I know of a few people that have used these pumps
https://daviescraig.com.au/category/electric-water-pump-12volt
Alan Jones
Re: MODIFY SB TIMING COVER FOR -AN [Re: LA360] #2797782
07/17/20 10:06 AM
07/17/20 10:06 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Not being a tig welder, I thought about just getting 2 AN fittings and have someone weld them into the water ports of the factory timing cover. First over the phone response to my suggestion was the welding shop wanted a new timing cover because of all the surface contamination of a used cover. They wouldn't guarantee results welding to a new one. I like the idea of having a remote pump. Clears up that area and affords a 3 row radiator or better yet a bigger electric fan.
Re: MODIFY SB TIMING COVER FOR -AN [Re: A/MP] #2797934
07/17/20 03:20 PM
07/17/20 03:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I would think a plate with the AN fittings attached would be the simplest way to add a remote pump, either welded or threaded. Several years ago a friend of mine ran a remote pump from grainger (I think) on a big block chevy. He said it was the same pump as one of the aftermarket retailers were selling for about 1/3 of the cost.
Re: MODIFY SB TIMING COVER FOR -AN [Re: justinp61] #2798069
07/17/20 08:53 PM
07/17/20 08:53 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The Durango rear heater pump Monte reccomended used to be about $75 from Dorman.
Re: MODIFY SB TIMING COVER FOR -AN [Re: slantzilla] #2798254
07/18/20 11:47 AM
07/18/20 11:47 AM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
You could also run the lines into the freeze out plugs in the center of the block. This was common on short deck blocks.
Re: MODIFY SB TIMING COVER FOR -AN [Re: NoFrills] #2798356
07/18/20 03:18 PM
07/18/20 03:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm going to put a remote pump on my street rod due to it having alot of angle on the rad to
make things fit but with that much angle the rad doent work at 100%.. if I put the remote pump
on I can stand the rad up more to have it work much better.. the pump I am looking at was the
last one shown.. puts out 40gph.. I can gain about 3" of room
wave
