Inline Tube E Body Rear Disc Brake Kit Opinions
#2795235
07/10/20 05:36 PM
07/10/20 05:36 PM
Posts: 156 Detroit, Mi
michiganhotrod1
Detroit, Mi
Hello; I have a 71 Cuda, currently set up with a Wildwood rear disc brake kit. It is impossible to use OEM 15" steel wheels of any kind, which is what i want to do. The Doctor Diff kit is not going to be available for three (or more?) months. Locally I can get a barely used Inline Tube /Pirate Jacks kit, 1966-74 Mopar Rear Disc Brake Conversion With Standard Rotors https://www.inlinetube.com/products/dbk834Anyone have any experience with this kit, good or bad? My experience with inline Tube is that I will not be able to get any decent information from them, and the web page is pretty limited. Any help is appreciated, I want to get this car back on the road! Thanks, Mark
Re: Inline Tube E Body Rear Disc Brake Kit Opinions
[Re: michiganhotrod1]
#2795400
07/11/20 10:42 AM
07/11/20 10:42 AM
Posts: 2,592 None
71rm23
None
Hello; I have a 71 Cuda, currently set up with a Wildwood rear disc brake kit. It is impossible to use OEM 15" steel wheels of any kind, which is what i want to do. The Doctor Diff kit is not going to be available for three (or more?) months. Locally I can get a barely used Inline Tube /Pirate Jacks kit, 1966-74 Mopar Rear Disc Brake Conversion With Standard Rotors https://www.inlinetube.com/products/dbk834Anyone have any experience with this kit, good or bad? My experience with inline Tube is that I will not be able to get any decent information from them, and the web page is pretty limited. Any help is appreciated, I want to get this car back on the road! Thanks, Mark Well, in my experience, I'd bite it and wait for Cass to come through. Cass (Dr. Diff) is a stand up vendor. Rome wasn't built in a day or Master Po would say "patience, grasshopper"
[Re: 451Mopar]
#2797315
07/16/20 10:11 AM
07/16/20 10:11 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I'm planning on a rear disc setup... heavily leaning towards the Dr Diff 10.7" rear setup for a few reasons: proven setup; can use 15" rims (I also want that option... to retain my 15" rims whenever I want, despite having larger diameter rims for occasional road course track days); the option to retain the favored factory-design tapered axle bearings -- superior and extremely critically important for lateral cornering loads, as well as allows for factory-designed axle end-play; has an optional e-brake cable. The only thing I wonder about is the availability of replacement parts for that Dr Diff setup... I'm uncertain, but I think the rotors are from a Camry, the calipers and pads are from a Ford small Mustang Cobra.
I'd only hope the the eventual swap will be a worth-while performance improvement... especially on the road courses... I've installed the larger 11.75" Cordoba brakes... still to be tested... soon... new engine waiting to be fired-up... then driven!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: DoctorDiff]
#2798910
07/20/20 12:47 PM
07/20/20 12:47 PM
Mopar Mitch
Dr Diff/Cass -- thanks for the info. I was unaware of your Ford Explorer 11.25" rear setup for our Mopars... something to re-consider, compare differences, etc.
Mopar Mitch
