Hemi 426 Engine Cradle? #2796091
07/13/20 10:00 AM
07/13/20 10:00 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Does anyone make an engine cradle for a 426 Hemi?
My motor is ready for the Dyno and I just realized I have no way of getting it there since the KB blocks only have the Hemi motor mounts.
I've look at Mancini, Allstar, Jegs and Summit....
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796095
07/13/20 10:04 AM
07/13/20 10:04 AM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
I would check with Ray Barton, Keith Black, Marsh Performance, Charlie Wescott and anybody else you can think of that does Hemi work.
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796100
07/13/20 10:13 AM
07/13/20 10:13 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I BOUGHT A SUMMIT ONE FOR A wedge, then cut off the front mounts and welded on flat stock. Drilled holes and that's it
....BAD A$$ STREET CAR.....
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796125
07/13/20 11:47 AM
07/13/20 11:47 AM
AndyF Offline
AndyF  Offline
Bob Mazzolini took over making them from me. He might have some on hand, if not new then perhaps used. Worth giving him a call.
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796130
07/13/20 11:57 AM
07/13/20 11:57 AM
Cab_Burge Online work
Cab_Burge  Online Work
I make mine out of wood to fit around the oil pan up Steels wheels on them to roll on concrete or no wheels to transport in the back of my truck to go to the dyno up scope
2x6 or 2x8 work great, I can even do them grin
Re: Hemi 426 Engine Cradle? [Re: n20mstr] #2796148
07/13/20 01:02 PM
07/13/20 01:02 PM
Tulsa, Ok
Tulsa, Ok
Coming up with Zero.
I found this on eBay so I'll give this guy a try, he already said he can build one and ship it tomorrow with some modifications.
I could modify one I have but I just don't have time at the moment.
Hemi engine cradle
I wished you were still making those Andy...
Cab, I have a few of those but they don't attach to the motor, just sit so for around the shop they work but in the back of the truck I like them to be bolted together.
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796171
07/13/20 02:17 PM
07/13/20 02:17 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Try
DRC Race Products
Phone 570-658-3515
He makes them to fit up on the water pump holes that will fit virtually any block hemi or wedge.
Todd
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796242
07/13/20 05:03 PM
07/13/20 05:03 PM
I use 3.5 inch long wood screws to hold mine together up
I had to make several of them (6) with wheels when we moved from SO CA up here to Bend, they all held up well. I recycle our old facial boards off of our house down there, 2x8. I tied them down to in floor tie downs for the car straps in my car trailer, it was a little over 850 miles one way luck I did use one piece of plywood on one of them on the bottom due to running out of the 2x8 boards, all the rest had longer front and rear boards to help make sure they wouldn't tip over
When I haul them in the truck I tie them down around the front and preload the back against the tail gate, 2006 ram 3500. No wheelies or sudden stop though whistling
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796244
07/13/20 05:10 PM
07/13/20 05:10 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Hemi engine cradle
I have one of those - nice well built cradle - super nice guy!
Re: Hemi 426 Engine Cradle? [Re: DoubleD] #2796336
07/13/20 10:43 PM
07/13/20 10:43 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Chuck Lofgren was having them made somewhere. I'm not sure if he still is, you could give him a call. (763) 753-7573
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi 426 Engine Cradle? [Re: Cab_Burge] #2796446
07/14/20 11:17 AM
07/14/20 11:17 AM
MI
MI Mopar Works Offline
MI
RCR Metal Fab
https://www.ebay.com/itm/Engine-Cradles-Stand-Heavy-Duty-Chrysler-426-Hemi-For-Alum-Iron-Blocks/111836087852?hash=item1a09f3462c:g:SzUAAOSwLTpbnxOA
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: Hemi 426 Engine Cradle? [Re: MI Mopar Works] #2796493
07/14/20 12:28 PM
07/14/20 12:28 PM
AndyF Offline
AndyF  Offline
Those look like they are heavy duty. More expensive than the ones I was making but might be worth it.
http://www.rcrmetalfab.com/home.html
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2796496
07/14/20 12:36 PM
07/14/20 12:36 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I've made transportation cradles out of 2X6 and plywood.
Something like this on a pallet
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi 426 Engine Cradle? [Re: W.I.N. Racing] #2796533
07/14/20 01:59 PM
07/14/20 01:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have always just built out own out of 1x1 square tubing. Usually use the motor plate as a front mount since many have accessories attached to them and they have mounting holes already
Re: Hemi 426 Engine Cradle? [Re: Al_Alguire] #2796559
07/14/20 02:57 PM
07/14/20 02:57 PM
AndyF Offline
AndyF  Offline
Yes, I switched over to motor plate mounting on the dolly for my race engine. That setup was just a little easier to put on and take off and it worked for multiple engines.
Re: Hemi 426 Engine Cradle? [Re: AndyF] #2796565
07/14/20 03:15 PM
07/14/20 03:15 PM
I made the first two wooden ones, my friend scab the steel one out of scraps he had on hand to give to me scope
Lots of choices to get the job done up
Re: Hemi 426 Engine Cradle? [Re: Cab_Burge] #2797973
07/17/20 04:40 PM
07/17/20 04:40 PM
NC
440Jim Offline
440Jim  Offline
NC
If you fab and weld your own connection to the Hemi mounts, this is what was on my KB block (dimensions).
Re: Hemi 426 Engine Cradle? [Re: 440Jim] #2798974
07/20/20 03:16 PM
07/20/20 03:16 PM
Tulsa, Ok
Tulsa, Ok
I ended up purchasing one from RCR and they are very very well built. I didn't have time modify/fabricate a standard big block one and glad I didn't now that I have this one.
RCR Metal Fabrication
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2798998
07/20/20 03:51 PM
07/20/20 03:51 PM
AndyF Offline
AndyF  Offline
Looks good, that design is much heavier than that ones I used to build. I did use larger casters on mine. I always put 5 inch casters on my cradles so they would roll really nice.
Re: Hemi 426 Engine Cradle? [Re: WadeMetzinger] #2799007
07/20/20 04:05 PM
07/20/20 04:05 PM
an8sec70cuda Offline
A $10.99 harbor freight furniture dolly (1,000 lb. capacity) and some scrap wood screwed to it works for me. Have several complete engines in the shop on them so I can move them around easily. They don't roll real good, but good enough.
CHIP
'06 GMC 2500HD LBZ Duramax
