Interesting 906 Heads
#2795771
07/12/20 11:41 AM
07/12/20 11:41 AM
6_pack_runner
6_pack_runner
Going through lots of parts I have laying around, decided to have these heads flowed. Searched some past 906 head threads, and these seam to be pretty good, especially considering the valve sizes 20200712_101644 by William Dewing, on Flickr
Re: Interesting 906 Heads
[Re: ]
#2795800
07/12/20 12:47 PM
07/12/20 12:47 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
How old are those results and what type of bench? If they where flowed on a good day, high pressure with cool temps and low humidity they may not have the same results when flowed on a hot, humid day on the same bench The real proof is in how well they run on a motor
[Re: Cab_Burge]
#2795874
07/12/20 04:31 PM
07/12/20 04:31 PM
6_pack_runner
6_pack_runner
They were flowed 10 days ago, they are a pair of legal Superstock heads, hence the small valves. A lot of "epoxy" and work done on them.
[Re: ]
#2795886
07/12/20 04:59 PM
07/12/20 04:59 PM
Cab_Burge
They were flowed 10 days ago, they are a pair of legal Superstock heads, hence the small valves. A lot of "epoxy" and work done on them. Those flow numbers are good for a iron head, not so good when compared to a decent set of new aluminum 440 replacement heads with bigger valves NHRA rules in SS do allow room for a lot of port work
[Re: Cab_Burge]
#2795900
07/12/20 05:45 PM
07/12/20 05:45 PM
6_pack_runner
6_pack_runner
They were flowed 10 days ago, they are a pair of legal Superstock heads, hence the small valves. A lot of "epoxy" and work done on them. Those flow numbers are good for a iron head, not so good when compared to a decent set of new aluminum 440 replacement heads with bigger valves NHRA rules in SS do allow room for a lot of port work I believe in SS the port work you are allowed is basically unlimited, but valve size is limited to .005 over stock, hence the 2.083 and 1.743 valve size, chambers and runners are limited to published numbers also
[Re: ]
#2795917
07/12/20 07:02 PM
07/12/20 07:02 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There are quite a few rules regarding what’s legal for SS, but the gist of it is...... there is a CC limit.
Those are actually pretty small at 195cc. They’re allowed to be 203.
I freshened a set last year...... they were about 10cfm less, and were closer to 203cc.
[Re: fast68plymouth]
#2795925
07/12/20 07:17 PM
07/12/20 07:17 PM
6_pack_runner
6_pack_runner
I freshened a set last year...... they were about 10cfm less, and were closer to 203cc. Outside of valve size, chamber and runner cc, and the intake face not getting into the valve cover holes, I think that is basically it. These were flowed on a 4.35 bore, but the engine they were on has a 4.39 bore. I forgot to mention that to them. With these smaller valves, would the larger bore affect flow much ?
[Re: ]
#2795928
07/12/20 07:32 PM
07/12/20 07:32 PM
Posts: 201 PA
Scully
PA
Going through lots of parts I have laying around, decided to have these heads flowed. Searched some past 906 head threads, and these seam to be pretty good, especially considering the valve sizes 20200712_101644 by William Dewing, on Flickr Those numbers are very similar to the 346 casting super stock heads I did for my engine.
[Re: Scully]
#2795969
07/12/20 09:24 PM
07/12/20 09:24 PM
Posts: 3,087 Michigan
A727Tflite
You are about 30 cfm down from a real good set of SS legal heads. About 17 up from a standard maxwedge head that has std. valves and ports.
[Re: A727Tflite]
#2796014
07/12/20 11:42 PM
07/12/20 11:42 PM
Posts: 201 PA
Scully
PA
You are about 30 cfm down from a real good set of SS legal heads. About 17 up from a standard maxwedge head that has std. valves and ports. The Stg 5 heads offer greater opportunity. I've had virgin Stg 3 heads on my bench, still had the studs and yellow springs and they are no where near 280 CFM at 28 inches.
[Re: 440Jim]
#2796155
07/13/20 01:24 PM
07/13/20 01:24 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It shows 302 cfm (intake) with clay radius. Is the 296 cfm with a radius plate or nothing? nobody in there right mind would flow an intake port without a radius plate. it just isn't done.
[Re: pittsburghracer]
#2796158
07/13/20 01:37 PM
07/13/20 01:37 PM
fast68plymouth
So. Burlington, Vt.
My interpretation of the sheet is...... the intake port was tested with a clay radius(as opposed to a radius plate).
The 302@.650 is a “footnote”, since that lift isn’t displayed in the normal increments.
In other words, the peak flow is 302@.650 lift.
[Re: Scully]
#2796206
07/13/20 03:48 PM
07/13/20 03:48 PM
fast68plymouth
So. Burlington, Vt.
I don’t know...... this one seems to have a flow range pretty close to 300 for the intake.
In fact...... all of the ranges used for that test on both intake and exhaust are pretty close to the ranges of the one in the pic.
