Air conditioning compressor oil #2795341
07/11/20 01:08 AM
07/11/20 01:08 AM
katakan
lilred Offline OP
lilred  Offline OP
katakan
Just wondering what oil should be used in a 1967 coronet air conditioning with factory twin cylinder pump?
Re: Air conditioning compressor oil [Re: lilred] #2795380
07/11/20 09:38 AM
07/11/20 09:38 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What type of freon?
Re: Air conditioning compressor oil [Re: Sniper] #2795412
07/11/20 11:09 AM
07/11/20 11:09 AM
katakan
lilred Offline OP
lilred  Offline OP
katakan
I'm probably going to use the consumer bottles (6oz) of Red Tek 12a equivalant to 18 oz of R12.
I also have a bottle (4oz) Red Tek oil charge, which says that it has 2 oz of oil lubricant.
Just to make it clear the oil I'm after is for the lower crankcase area of the factory twin cylinder A/C compressor, from the service manual it appears to say that eventually the oil in the lower crankcase gets mixed in with the freon in the whole system, seems like that is a separate area just to lube the bottom end and pistons in the A/C compressor similar to a normal car engine with the lower separate from the top end??
Re: Air conditioning compressor oil [Re: lilred] #2795476
07/11/20 01:58 PM
07/11/20 01:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
While the crankcase oil does lube the compressor lower end, it also migrates throughout the system before returning to the compressor. Red Tek is (supposedly) compatible with mineral and synthetic (Ester and PAG) oils.
Re: Air conditioning compressor oil [Re: John_Kunkel] #2795481
07/11/20 02:06 PM
07/11/20 02:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
As far as I can remember the factory service manual showed how to make a dipstick. You removed a plug at the rear of the compressor and checked the level. You also added what was needed at the same spot. This took care of the complete system and no other oil is added.
Re: Air conditioning compressor oil [Re: John_Kunkel] #2795490
07/11/20 02:24 PM
07/11/20 02:24 PM
GMP440 Offline
GMP440  Offline
Yes, that's correct about the dipstick to check the refrigerant oil level in the compressor. But, to check the level the system has to be bled down.
Re: Air conditioning compressor oil [Re: GMP440] #2795557
07/11/20 05:37 PM
07/11/20 05:37 PM
katakan
lilred Offline OP
lilred  Offline OP
katakan
Yes, i saw the whole make your dipstick BS in the service manual, shows to make a dipstick for both sides, the sump plug filler hole and the crankcase oil filler hole.
Just want to make sure to put the correct type of oil in the POS, LOL.
Re: Air conditioning compressor oil [Re: lilred] #2795640
07/11/20 10:50 PM
07/11/20 10:50 PM
GMP440 Offline
GMP440  Offline
Check with Napa. They may still sell the mineral oil for R-12 systems. They came in quart containers.
Re: Air conditioning compressor oil [Re: lilred] #2795644
07/11/20 10:55 PM
07/11/20 10:55 PM
GMP440 Offline
GMP440  Offline
Re: Air conditioning compressor oil [Re: GMP440] #2798188
07/18/20 08:01 AM
07/18/20 08:01 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I still have an unopened 30# cyl.of R12 in my basement.
