saftey neutral switch 67 gtx 727 #2795369
07/11/20 08:20 AM
07/11/20 08:20 AM
ny
marcjames Offline OP
ny
how do you wire up 67 saftey switch on trans it has one wire hook up i know it goes to starter relay thanks
Re: saftey neutral switch 67 gtx 727 [Re: marcjames] #2795384
07/11/20 09:46 AM
07/11/20 09:46 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
not sure what you are asking.
There is only one place you can hook a wire up to on a 67 NSS, no options.
Are you asking where to hook the other end of the wire up on the starter relay?
If so that would be the "G" terminal, assuming you have an automatic trans starter relay.
Re: saftey neutral switch 67 gtx 727 [Re: Sniper] #2795387
07/11/20 09:55 AM
07/11/20 09:55 AM
ny
ny
yes to the starter relay i have no wire pig tail is it just one wire thanks mopar friend
Re: saftey neutral switch 67 gtx 727 [Re: marcjames] #2795388
07/11/20 09:59 AM
07/11/20 09:59 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yes - it is just a single wire.
Re: saftey neutral switch 67 gtx 727 [Re: markz528] #2795414
07/11/20 11:13 AM
07/11/20 11:13 AM
ny
ny
thank you
Re: saftey neutral switch 67 gtx 727 [Re: marcjames] #2795488
07/11/20 02:21 PM
07/11/20 02:21 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Should be the push on connector on the lower right as you look at the photo.
Re: saftey neutral switch 67 gtx 727 [Re: 6PakBee] #2795600
07/11/20 08:09 PM
07/11/20 08:09 PM
ny
ny
thanks mopar friend pictures are very helpfull
