tone ring #2794882
07/09/20 06:40 PM
07/09/20 06:40 PM
Duloc
The Shadow Offline OP
Duloc
I just found out I need to change my tone ring to the latter 58.
Does the crank need to be completely removed or is there a trick to get around disassembling it all again?
Re: tone ring [Re: The Shadow] #2794933
07/09/20 08:43 PM
07/09/20 08:43 PM
USA
hudsonhornet7x Offline
USA
Unfortunately the crank will need to come back out. May I ask what your setup is, in other words what are you using that will require the 58x reluctor wheel?
Re: tone ring [Re: hudsonhornet7x] #2795052
07/10/20 09:02 AM
07/10/20 09:02 AM
Duloc
Duloc
That's what I was afraid of.
Bs3 cop system
