Torque Converters - Who Do You Like? #2793967
07/07/20 04:05 PM
07/07/20 04:05 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Looks like I'm in the market for a torque converter after testing the my stall speed. When I checked it, the motor pushed it to 6500 and I was told it really can't be tightened up enough. So.... who do you guys like for quality and service?
572in
900hp @ 7100
750lbs tq @ 5400
727
Re: Torque Converters - Who Do You Like? [Re: JACK1440] #2793975
07/07/20 04:18 PM
07/07/20 04:18 PM
PA
Harry's Taxi 2 Offline
PA
Dynamic.....I just did some converter/rear gear testing with 5 converter swaps. Turbo-Action for a second choice.
I won't do any direct company bashing, but will say that the more advertised, three initialed ones seem to think the looser the better.......I have a couple of friends cars, two that are verified 1000+ h.p. and one 900+ (both original builders dyno's and verified on local dyno's after refreshes) and they both e.t. and mph as if they're short about 200+ h.p.....two dragsters and the other a door car....after trying multiple three initial converters that worked almost exactly the same, they gave up and just live with having 200 h.p less et's......and yes all three have data recorders showing exactly what's going on. Guess GER never really went out of business, just changed some letters and opened multiple locations.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Torque Converters - Who Do You Like? [Re: Harry's Taxi 2] #2793978
07/07/20 04:34 PM
07/07/20 04:34 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Turbo Action, call and talk to Paul. He will ask allot of questions.
Re: Torque Converters - Who Do You Like? [Re: Dodgeguy101] #2793982
07/07/20 04:50 PM
07/07/20 04:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Ultimate
PTC
I have had great customer service from both of these places.
....BAD A$$ STREET CAR.....
Re: Torque Converters - Who Do You Like? [Re: n20mstr] #2794015
07/07/20 06:28 PM
07/07/20 06:28 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Ultimate... have three of them, two of them ( one in car, one spare ) original T/A 904 8 inch redone by Ultimate for combo change, the other a 518 lockup redone.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Torque Converters - Who Do You Like? [Re: 11secdart] #2794049
07/07/20 07:57 PM
07/07/20 07:57 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I love PTC, but have heard a lot of good stuff about Dynamic
1969 Dodge Dart Swinger
Re: Torque Converters - Who Do You Like? [Re: MikeyT] #2794081
07/07/20 09:21 PM
07/07/20 09:21 PM
Washington
skrews Offline
skrews  Offline
Washington
ATI
Re: Torque Converters - Who Do You Like? [Re: skrews] #2794131
07/08/20 12:04 AM
07/08/20 12:04 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Dynamic
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Torque Converters - Who Do You Like? [Re: BloFish] #2794172
07/08/20 06:34 AM
07/08/20 06:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Try yours first. Im betting it's an 8". May not be as bad as you might think. Currently mine runs an Ultimate 9.5" 6000 fall back and an ATI 9.5 6100 fall back. I've run an ATI 9.5"in the past that was 6300 fall back It ran as good as both of the ones I have now. Thought it would be way to loose. Not so. Mines never been on the dyno but it's a 15-1 572 that has out run more than a few that have dynoed over 900. Weve had good service from PTC as well. A few buddy's using Perfect Conveter near Cleveland. Last time he went 1.26 like clockwork. 3400lbs, 10.5x31, footbrake. His dyno numbers are nearly identical to yours. It has a 572 from Best Racing Engines.
Doug
Re: Torque Converters - Who Do You Like? [Re: dvw] #2794184
07/08/20 08:08 AM
07/08/20 08:08 AM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Doug, sounds like you're making good power. What made me suspicious is I was out a few weeks ago and it felt like it was almost slipping. Turns out there was basically no fall back at the shift. That the main reason I checked the stall speed. It is an 8". Dynamic told me I should go to a 9". Lot's of good input on. Thanks guys!
Re: Torque Converters - Who Do You Like? [Re: skrews] #2794196
07/08/20 08:57 AM
07/08/20 08:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A1, ATI and FTI have all been very good for me. Which one used depends on the application honestly.
Re: Torque Converters - Who Do You Like? [Re: Al_Alguire] #2794203
07/08/20 09:14 AM
07/08/20 09:14 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I have had good luck with PTC, since 2004
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Torque Converters - Who Do You Like? [Re: 11secdart] #2794212
07/08/20 09:40 AM
07/08/20 09:40 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What he said.... 2 727 and 1 904. No complaints
Re: Torque Converters - Who Do You Like? [Re: J_BODY] #2794222
07/08/20 09:56 AM
07/08/20 09:56 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So you have run the converter you have at the track already? If not that the best place to start, look at finish line RPM and shift recovery RPM and that will tell you the story of whether its any good or not. As for buying one if you have a dyno sheet that's great. Even better is having a dyno sheet from a dyno your converter guy of choice is familiar with, since they all vary somewhat. Also if you have info on your current converter, especially if you do not have dyno info would also be helpful for the converter company of choice. As you see from this post opinions on converter companies will vary. I am also a firm believe that you have to try stuff in this are, many guys will tell you I love this company my converter is great but its the only one they have ever tried in their combo..As for a couple mentioned I would RUN fast the other way but again just my opinion.
Re: Torque Converters - Who Do You Like? [Re: JACK1440] #2794226
07/08/20 10:00 AM
07/08/20 10:00 AM
Texas
RustyM Offline
RustyM  Offline
Texas
We tried FTI converters out of Florida for two units this last time, have one full season on them and two races this year- good units, no issues, great folks, great tech support, good price.
Good enough we haven't had to think about/worry about the converters.
Re: Torque Converters - Who Do You Like? [Re: Al_Alguire] #2794348
07/08/20 01:43 PM
07/08/20 01:43 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Hey Al, I did run the car about 3 weeks ago. That's where my doubt started. There was basically no fall back at the shift. Then when I contacted the company that built the converter they confirmed the converter wouldn't hold my combo and I should step up to a 9". Thanks for the input. I appreciate it.
Re: Torque Converters - Who Do You Like? [Re: JACK1440] #2794359
07/08/20 02:10 PM
07/08/20 02:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Heavy-ish car, mid-rpm level high tq big cube motor + 8” converter doesn’t sound like the hot ticket to me.
From the sounds of it, you’re just driving right thru it...... which is what I’d expect.
I know of a few people who were having similar experiences with their combos and saw good results by switching to an Ultimate 9.5” unit.
My friend with the 572 powered charger than runs low 9’s has a race 10” from ATI that works really well.
Re: Torque Converters - Who Do You Like? [Re: JACK1440] #2794373
07/08/20 02:48 PM
07/08/20 02:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I really like my TA converters(have 2 of them) also have a Ultimate and a few others
wave
Re: Torque Converters - Who Do You Like? [Re: MR_P_BODY] #2794386
07/08/20 03:21 PM
07/08/20 03:21 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'll be the odd man out here, but Ultimate missed my converter twice. Kenny Ford helped it but it still wasn't right. I installed a new Coan but am waiting on shocks before I can get to the track to see what I have. Not condemning Ultimate, I just didn't get good results for the money I spent.
Re: Torque Converters - Who Do You Like? [Re: BloFish] #2794467
07/08/20 06:58 PM
07/08/20 06:58 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by BloFish
Dynamic
That is all I have ever used and have had zero complaints over the last 35+ years. They are finishing one for me right now.
