Page 7 of 7 1 2 3 4 5 6 7
Re: budget turbo Belvedere still alive and well [Re: cudaman1969] #1373466
01/02/14 07:52 PM
01/02/14 07:52 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
For a smaller displacement street motor, go with a .81-.96 turbine A/R and a decent compressor size. I bought the 1.05 A/R housing and it spools SSLLOOWWW on my 318. I wish I would have known more and I would have got something smaller.
Re: budget turbo Belvedere still alive and well [Re: SLOW67] #1373467
01/02/14 09:17 PM
01/02/14 09:17 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That's where I don't agree. Mine is a 1.32 A/R and a 96mm wheel...
With a 2600 (on motor only) stall. I could foot brake 1200rpm into the beams, grab the trans brake and floor it as soon as I staged the car. I could be to 10psi before the bottom bulb went on without an issue.
So zero boost to full boost in 1 second. I can also go from 8psi to 20psi in under a second after a I let go of the trans brake.
Just depends on what your definition of "slow" spooling is I guess. But mine is not bad at all in my opinion.
Here is a video of mine from rolling on the throttle in the car... you can hear it doesn't take long to spool up at all.
https://drive.google.com/open?id=0B-3Ko4PYG9SvUUJGYXZQTkdQa28
Here is one from a roll in first that I flat foot it. (you can hear the big ol' pedal hit the floor... lol
https://drive.google.com/open?id=0B-3Ko4PYG9SvY0QxMXluaUdhUWc
That being said, after I tightened the converter so it will only go to 2200rpm on motor, it's absolutely TERRIBLE on spool up. But I blame the converter, not the turbo A/R.
Just like anything, you just need to match the components to make them work good.
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373468
01/02/14 10:25 PM
01/02/14 10:25 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I imagine mine would spool well on a tbrake but off the footbrake with a tight converter it sucks
Re: budget turbo Belvedere still alive and well [Re: SLOW67] #1373469
01/02/14 10:39 PM
01/02/14 10:39 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I believe that!
Plus with the 318, it isn't exactly a torque monster without the turbo.
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373470
01/02/14 10:41 PM
01/02/14 10:41 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I believe that!
I'm ready for my 360 to be in but I'm going to swap to the glide first with a better converter and see what the 318 will do all out. O yeah and it's got 100hp worth of nitrous for that too lol
Re: budget turbo Belvedere still alive and well [Re: cudaman1969] #1373471
01/08/14 02:49 AM
01/08/14 02:49 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
It's winter here so I won't have any updates till spring.
M1 is VP Methanol for those that think it's a intake.
Pic is from Cordova World series 2014.
If your still building boost but it topped out you need a bigger exhaust housing, or complete bigger turbo
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373472
01/15/14 08:37 AM
01/15/14 08:37 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Oops World series 2013, but we will be there in 2014
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373473
01/19/14 01:10 AM
01/19/14 01:10 AM
south central nebraska
GI Moparman Offline
GI Moparman  Offline
Really liking the idea of putting a turbo on 383 in a slick old f5 belvedere 1 4door. Any advantages/disadvantages of using a 4 speed with that engine set up?
Re: budget turbo Belvedere still alive and well [Re: GI Moparman] #1373474
01/19/14 01:12 AM
01/19/14 01:12 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
4 speed won't build boost as easy as an automatic will. No converter to load against at the starting line, no "flash stall" to make RPM from a roll.
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373475
01/19/14 01:37 AM
01/19/14 01:37 AM
GI Moparman Offline
GI Moparman  Offline
I meant 65 not f5. So if I was to use a basicly stock engine, small cam, would a stock convertor work? Say a 2200 stall?
Re: budget turbo Belvedere still alive and well [Re: GI Moparman] #1373476
01/19/14 01:21 PM
01/19/14 01:21 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just depends on what you're goals are. But if you keep the boost down, it won't break parts.
Anything will make power with boost. I think quickd100 has proven that.
Stock 318...
https://board.moparts.org/ubbthreads/show...rue#Post7933900
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373477
02/07/14 03:55 AM
02/07/14 03:55 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
A tight 3500 stall made a night and day difference in mine.
But I have a Comp 280,480 cam in it also.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #2792876
07/05/20 09:45 AM
07/05/20 09:45 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
It's been ages since I've been on here.
The budget turbo Belvedere is still kicking, Msd 7531 box, C&S Aresol and a much larger turbo.
383 is still basically stock.
Hopefully I'll get it back to the track eventually!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #2793295
07/06/20 09:44 AM
07/06/20 09:44 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Welcome back wave
Rich H.
Esse Quam Videri
Re: budget turbo Belvedere still alive and well [Re: ZIPPY] #2793846
07/07/20 10:42 AM
07/07/20 10:42 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Cool, glad to hear the old Belvy is still running!
2 kids and a dog
Re: budget turbo Belvedere still alive and well [Re: TonyS451] #2793955
07/07/20 03:52 PM
07/07/20 03:52 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Here is a pic @ Cordova for the World Series 2015. 62 years straight.
Last time they had that event before new owners moved it.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #2793960
07/07/20 03:58 PM
07/07/20 03:58 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Foot brake column shift bench seat.
I melted the stock cast pistons before this launch.
I warmed it up on the return road.
My timing map was messed up somehow.... O well
I think the old girl held up good to 7 years if 20+ lbs of boost non intercooled.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #2793965
07/07/20 04:02 PM
07/07/20 04:02 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I posted in this thread back in 2013 regarding my future 383 turbo plans for my '69 Super Bee... though Id share that I finally built mine and took it out for its maiden voyage just a few days ago.
Paul
'69 Super Bee 383 EFI Turbo
