New Garage floor NON-SLIP Epoxy ? ? ? #2793869
07/07/20 11:48 AM
07/07/20 11:48 AM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Hello All ! wave Hope everyone is doing well ! thumbs
Any recommendations on putting a NON - SLIP Epoxy on brand new garage floor ? ? ? shruggy
Brand new house that gets 95 degree heat & 20 degree snow on occasion ...... ( Neighbor had "something" put down & he's VERY disappointed as it's a 'Banana Peel' when wet ! eek )
Any services that do this ? I'm 65 and not sure I could do a project like this work Any & all help very warmly appreciated ! bow Kevin
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: kidmopar] #2793904
07/07/20 01:47 PM
07/07/20 01:47 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
When its installed you can get a silica sand type product that makes it very non slip along with the paint chips. They also recommend sanding and acid etch of the concrete, sealing and then paint.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: Savoy1964] #2794056
07/07/20 08:16 PM
07/07/20 08:16 PM
NW/Indiana - Chi town
ricomondo Offline
ricomondo  Offline
I live in Indiana and had a company come out from about 2 hrs away. Epoxy with the colored flakes and a bit of aluminum silica for grip. It can still be a bit slippery, but on my last garage I had them use a lot of silica and the mop head left all kinds of fuzz from the grip. There's a happy medium I'm sure. And as mentioned above, they will still have to diamond grind the concrete for proper adhesion, new pour or not.
GY3 71 Demon 340
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: kidmopar] #2794134
07/08/20 01:08 AM
07/08/20 01:08 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I use a solvent based two part quality epoxy (Palguard) for color, toughness, and adhesion. I don't believe an etch or sand blast or grind is necessary for all the garage floors I have done. More important they be dry, and as oil free as you achieve. Oil that soaks into raw concrete, is not mechanically removed, period. After the above epoxy cures, I top coat the epoxy with clear two part solvent based urethane, which looks and wears great, doesn't dull/chalk, and makes clean ups a cinch, when wet, its slippery, and I'm OK with that. I believe any additives applied for extra grit, are just a never ending future source of "dust", as the gritted surface abraids, the whole point I paint raw concrete in the first place. So pick your poison.
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: jcc] #2794370
07/08/20 02:38 PM
07/08/20 02:38 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
THANK YOU ALL ! For some GREAT replies ! bow up thumbs
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: kidmopar] #2794378
07/08/20 03:02 PM
07/08/20 03:02 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Keep in mind that while the abrasive silica they give you to put down is good for traction when the floor is wet, it makes the floor a total pain to clean. That stuff tears up anything you try to use to mop up messes. I did my own U CoatIt epoxy on the floor on the garage at my previous house it that stuff was hard to get spread around evenly and was no fun to try to clean.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: lilcuda] #2794380
07/08/20 03:09 PM
07/08/20 03:09 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I just coated part of my garage floor w a new Rustoleum product, I did NOT use the included paint chips to prevent slipping for exactly that reason my floor is a working floor and making it easier to keep clean was the purpose of the coating. My advice in applying it, is apply it thicker than you think, I sporead mine too thin and got a lot of pin spots as a result.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: kidmopar] #2794651
07/09/20 10:24 AM
07/09/20 10:24 AM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
I used a product called Shark Bite on my car trailer and four post lift ramps and rails. Made a big difference. You can mix it in the paint or you can have the store mix it for you.
Re: New Garage floor NON-SLIP Epoxy ? ? ? [Re: 6PacCuda] #2794681
07/09/20 12:17 PM
07/09/20 12:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A buddy of mine did something different on his 6000SF shop floor:
He had the concrete polished and waxed, and despite how it sounds, it wasn't slippery but cleaned up nicely.
He's a pretty thrifty guy, but he'd also had a painted floor in a previous shop and was concerned about chips & peeling.
We did all manner of fab & restoration & maintenance work there.
Only "problem" is it didn't reflect light.
That said, now that he's retired and has a LOT of money, his new 2400 SF "toy shop" does have a painted floor...
And it's showing some wear in heavy-traffic areas after about 10 years.
