Re: Flex Pipe Question
[Re: vadartlover]
#2793475
07/06/20 03:09 PM
07/06/20 03:09 PM
Posts: 6,290 nowhere
Sniper
nowhere
Depends on what pipe you actually are looking at. I know of two styles and they are bendable to some extent. Neither are real good for smooth flow, imo. Dynomax 46975 for example, spiral wound steel tube basically. Bellows style, all one piece.
[Re: Sniper]
#2793493
07/06/20 03:51 PM
07/06/20 03:51 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
I have seen these on turbo set ups
[Re: CSK]
#2793511
07/06/20 04:18 PM
07/06/20 04:18 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I have seen these on turbo set ups Those braided style flex couplers come OE on a lot of FWD cars. They usually use it between the manifold and the rest of the exhaust. Since those engines are transverse mounted, the exhaust has to absorb some fore/aft movement. A solid pipe won't work in that situation. I can remember back in the late 90's when a car came into the shop with a bad flex coupler like that. We replaced it with another flex coupler. A few months later, the car was back with an exhaust leak. The new coupler was bad. Turns out that the car had a bad engine mount and there was excessive fore/aft movement which took out the coupler.
[Re: burdar]
#2793523
07/06/20 04:59 PM
07/06/20 04:59 PM
Posts: 21,833 Kirkland, Washington
Pacnorthcuda
Some short sections were OEM on new Kenworth’ up at the turbo area for the same reason—engine movement.
Don’t like seeing that stuff on vintage muscle though.
[Re: Sniper]
#2794054
07/07/20 08:09 PM
07/07/20 08:09 PM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
Depends on what pipe you actually are looking at. I know of two styles and they are bendable to some extent. Neither are real good for smooth flow, imo. Dynomax 46975 for example, spiral wound steel tube basically. We used that stuff back in the early 70's when a properly done exhaust was not in the budget. It would last a couple of months and then unravel LOL.
[Re: poorboy]
#2794220
07/08/20 09:55 AM
07/08/20 09:55 AM
Sniper
nowhere
Any flex tubing for exhaust I've seen usually has a pretty short life expectancy. That is the truth right there. I only used it once when I swapped a 360 in place of the 225 in my Dart and I needed to save up for a dual exhaust. Used the donor car's Y pipe and in the trunk of the donor was a new muffler and piece of flex tubing. Lasted till the next payday and in it went for duals.
