windage tray on my 505 #279269
04/06/09 02:16 PM
04/06/09 02:16 PM
hartsburg mo
biggerredz71 Offline OP
hartsburg mo
My 440source windage tray did not fit my new stroker build,Will i be alright not running one or should i get a new one?The one i got from source was supposed to fit my 4.250 stroke,but dosent fit.
Re: windage tray on my 505 [Re: biggerredz71] #279270
04/06/09 03:34 PM
04/06/09 03:34 PM
Arkansas
defiance Offline
defiance  Offline
Arkansas
odd - how does it not fit? interference with the crank?
I'm running one on a 4.25" stroke, but then again, I've got it under a girdle, so it's dropped 3/8" or so.
As for whether you can run one without, sure, but you'll lose the benefit of it. How much of a difference that makes could be minimal or noticeable depending on your build
Re: windage tray on my 505 [Re: biggerredz71] #279271
04/06/09 04:08 PM
04/06/09 04:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Are you using their stroker tray or the standard one ???
Re: windage tray on my 505 [Re: Stanton] #279272
04/06/09 05:43 PM
04/06/09 05:43 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
what about a crank scraper ?
