SLAP STICK SHIFTER REBUILD #2792463
07/03/20 10:15 PM
07/03/20 10:15 PM
N.E. OHIO
P
polara426 Offline OP
P
N.E. OHIO
Anyone rebuild and replace the Chrome bezel on 71 to 74 B Body auto shifter I see the repro bezels but the original looks like it is riveted on? The replacement looks like it has screws.
Re: SLAP STICK SHIFTER REBUILD [Re: polara426] #2792722
07/04/20 05:55 PM
07/04/20 05:55 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I just rebuild the unit in my 71 e body. Took it completely down, including the shifter mechanism, and re-viveted everything back to one piece. I was able to polish the plastic back to useable, but replaced the chrome trim with the screen on piece. You have to grind out the rivets to get the original off. The screws go through the same holes on the baseplate. Very easy to do.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: SLAP STICK SHIFTER REBUILD [Re: A39Coronet] #2793693
07/06/20 10:46 PM
07/06/20 10:46 PM
N.E. OHIO
P
P
N.E. OHIO
Thanks looks great.
Re: SLAP STICK SHIFTER REBUILD [Re: A39Coronet] #2794648
07/09/20 10:18 AM
07/09/20 10:18 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
When I originally had the chrome shifter plates reproduced thru PG Classic, I had them made so the average person could install them. The originals had pot metal studs on the plate schwedged down to the metal plate so there's no other way to mount a re-chromed plate other than epoxy or small screws like the reproductions to remount it.
Re: SLAP STICK SHIFTER REBUILD [Re: HEMICUDA] #2794709
07/09/20 01:13 PM
07/09/20 01:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thank you for putting some extra thought into that reproduction part. up
Re: SLAP STICK SHIFTER REBUILD [Re: autoxcuda] #2794903
07/09/20 07:37 PM
07/09/20 07:37 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Nice added detail Mike!
