Master Cylinder Corrosion #2792367
07/03/20 03:54 PM
07/03/20 03:54 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
Most old iron MC's (used with glycol fluid) that I've disassembled have pitting in the bottom of the bore. I've only disassembled one later aluminum MC and it wasn't pitted.
Anybody with more experience with the aluminum MC's, do they tend to not be corroded inside over time like iron?
Re: Master Cylinder Corrosion [Re: John_Kunkel] #2792376
07/03/20 04:16 PM
07/03/20 04:16 PM
moparx Offline
moparx  Offline
i have had the same experience as you, except i have torn apart six or eight late model aluminum masters [mini van units] to just investigate the differences between years.
beer
Re: Master Cylinder Corrosion [Re: moparx] #2792380
07/03/20 04:20 PM
07/03/20 04:20 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
That along with weight are the reasons they moved from cast iron to aluminum castings.
Re: Master Cylinder Corrosion [Re: Mastershake340] #2792387
07/03/20 04:52 PM
07/03/20 04:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Aluminum M/C's have the bore anodized so corrosion shouldn't be an issue but as with everything there is always an exception.
Re: Master Cylinder Corrosion [Re: Sniper] #2792574
07/04/20 10:17 AM
07/04/20 10:17 AM
VA
dragon slayer Offline
VA
Won't react to moisture like iron, but I have seen the aluminum pistons corrode/pit. Maybe only when in contact with steel too (shims, springs). Probably galvanic corrosion.
