Electronic Voltage regulator for 69 mopars #2792173
07/03/20 06:33 AM
07/03/20 06:33 AM
Abilene, Texas
fastmark Online content OP
fastmark  Online Content OP
Abilene, Texas
I’m trying to find the best new electronic regulator that looks like the old 69 down style and plugs into the 69 harness. Classic industries sells one but I’m sure it’s made overseas anyone have a better source? Or is the one from Classic ok?
Re: Electronic Voltage regulator for 69 mopars [Re: fastmark] #2792194
07/03/20 08:18 AM
07/03/20 08:18 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I had one crap out on me. I looked around for a higher end replacement but couldn't find one. All the original looking regs. I found were the same $15 piece. I just bought 2, and keep the spare in the glove box. My first one failed in a "max charge" condition.
Re: Electronic Voltage regulator for 69 mopars [Re: fastmark] #2792197
07/03/20 08:41 AM
07/03/20 08:41 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as far I have read there are mixed experiences from diff sources, so I'd say is about lotely... althought the best you can get is some seller able to get somehow on return guarantee.
Re: Electronic Voltage regulator for 69 mopars [Re: fastmark] #2792217
07/03/20 09:23 AM
07/03/20 09:23 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
The Mopar Performance 312-P3690732 I just got from Jegs said "Made in the USA" on the box.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Electronic Voltage regulator for 69 mopars [Re: A39Coronet] #2792239
07/03/20 09:56 AM
07/03/20 09:56 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that is supossely "for race only" constant output
Re: Electronic Voltage regulator for 69 mopars [Re: A39Coronet] #2792240
07/03/20 10:00 AM
07/03/20 10:00 AM
32034
savoy_63 Offline
savoy_63  Offline
32034
That one does not look like the OEM 69
Re: Electronic Voltage regulator for 69 mopars [Re: NachoRT74] #2792241
07/03/20 10:08 AM
07/03/20 10:08 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I've got that one on my '68, since 1975, never had an issue with it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Electronic Voltage regulator for 69 mopars [Re: 3hundred] #2792265
07/03/20 10:58 AM
07/03/20 10:58 AM
CrazyD Offline
CrazyD  Offline
Autozone/Wells VR706 regulator, then put old cover on top of it.
Re: Electronic Voltage regulator for 69 mopars [Re: CrazyD] #2792331
07/03/20 01:03 PM
07/03/20 01:03 PM
NAPA sells one, I have one on my 1966 Dodge Coronet. I haven't drove that car yet so no comment on how good they are shruggy
Re: Electronic Voltage regulator for 69 mopars [Re: fastmark] #2792453
07/03/20 09:14 PM
07/03/20 09:14 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
[J&N Electric Made In USA
Part # 230-10001
exact match, works perfectly, no more dimming headlights at idle. Marked Field?IGN just as factory. If you cannot source one on your own I'll sell one of my supply.
Re: Electronic Voltage regulator for 69 mopars [Re: fastmark] #2792520
07/04/20 05:27 AM
07/04/20 05:27 AM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
I have been selling these for more than 15 years. While made in China, they are not junk. I've been using these in my cars for 15 years with no issues.
https://www.ebay.com/itm/121703672807?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Re: Electronic Voltage regulator for 69 mopars [Re: furygt] #2792526
07/04/20 06:30 AM
07/04/20 06:30 AM
Abilene, Texas
Abilene, Texas
Thanks for the help guys.
Re: Electronic Voltage regulator for 69 mopars [Re: 3hundred] #2793351
07/06/20 11:52 AM
07/06/20 11:52 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I have had really good luck running the all electronic Regitar C524 voltage regulator, which Fury GT referenced above.
Alt needle is rock solid. I have had no problem running them with the new Powermaster 90 amp alternators (though I should note that I have new harnesses throughout). At idle the charging system is giving me a steady 14.6V
fury GT sells them on e-bay, a couple of electronic parts suppliers sell them as well. One other note, I am really careful to make sure the VR is grounded well on the firewall.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
