Dakota Tachometer reading incorrect #2791951
07/02/20 03:48 PM
07/02/20 03:48 PM
usa
Mopar1970440 Offline OP
usa
1994 Dakota 5.2 with 5 speed manual transmission
Tachometer seems to be reading at least double what the engine is actually RPMing at. Example: The engine is running about 2,000 rpm the tachometer is reading 4,000ish and then sometimes the tachometer is just acting all sorts of wacky bouncing around.
What is the way to go about diagnosing this kind of issue? Cluster? Some type of sensor? Thanks
Re: Dakota Tachometer reading incorrect [Re: Mopar1970440] #2792007
07/02/20 07:40 PM
07/02/20 07:40 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Sorry, no help here, just commenting because I'm in the same boat.
I'm having issues with the tach in my '92 Dakota. What I've noticed with mine though is when it 'flat-lines' (doesn't read anything) it almost feels like the brakes are dragging, the truck looses its 'snap'. It's a subtle difference, but there is a difference.
I'm not sure how to diagnose it though. Yours might be easier being OBDII , but I don't know.
I've asked about the tach in my truck a few times, but no one seems to know how to diagnose it. A member here offered a known good tach to me and I swapped it in but no real difference was seen.
shruggy
John
Re: Dakota Tachometer reading incorrect [Re: SattyNoCar] #2792300
07/03/20 12:12 PM
07/03/20 12:12 PM
CHRGR69 Offline
CHRGR69  Offline
Same here with my 89 Dakota 3.9. Bouncy tach????
Grandma always said I had "hands of gold"!
Re: Dakota Tachometer reading incorrect [Re: Mopar1970440] #2808227
08/12/20 08:50 PM
08/12/20 08:50 PM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
If you remove the instrument cluster, you'll see a little circuit board about 2" x 3" or so. it snaps off of the cluster. A lot of times you can actually see cracks or dimples around the larger solder joints on that board. Take your soldering iron and maybe just a small amount of new solder and re-flow those joints. Take care not to bridge any circuits with solder. Pop the board back onto the cluster and install it back into the truck. It should work much better.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
