Re: Mega block questions
[Re: cudaman1969]
#2791919
07/02/20 01:01 PM
07/02/20 01:01 PM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
Really not 100% sure if you mean Hemi or Wedge since both blocks were made from that common casting. It seems more of a Hemi question since that's the only one with round 4.25" chambers, but maybe you were talking about a 906-452 kind of a thing since they are nearly round, sort of?
Most Wedge stroker configurations make plenty of compression with a flat piston. You adjust clearance with gasket + machine work/deck height of the block/how far in the hole they are.
Most 4.500 Hemi pistons....more accurately the ones that I have seen (only a half dozen or so, so not very many TBH) are flat around the outside edge (as shown) to get around any issues. That being true, then the deck height/how far the flat area is in the hole + gasket also creates your clearance right there.
Rich H.
Esse Quam Videri
[Re: cudaman1969]
#2792481
07/03/20 11:09 PM
07/03/20 11:09 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I chamfer the head if there is not enuff clearance.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: cudaman1969]
#2794287
07/08/20 11:52 AM
07/08/20 11:52 AM
ZIPPY
S.E. Michigan
Should of said Hemi sorry. Your picture seems to answer the question, just thinking of that sharp edge, could ease it a little. What compression is in your pic. I’ll have a 4.5 crank so I’m thinking not to much dome for 10.1 and stock head. Maybe aluminum sometime in the future as the money comes around. Been a few days, just thought to catch up with this thread. 10.3, basically the same combination you're asking for in the parts wanted area, so this is about how much dome you will want. 4.5 stroke, std deck height, 7.100, .990. These are package number 804IN from Diamond, and I believe they are probably Indy's 572 crate engine piston although I can't prove that, and I did not buy them from Indy. You're looking at about a 73 to 75cc dome to be in the low 10s for compression like you want. The edges are all broken by cnc right out of the box, there aren't any sharp edges. It's hard to tell by the pictures though.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2794296
07/08/20 12:05 PM
07/08/20 12:05 PM
Posts: 8,349 fredericksburg,va
cudaman1969
fredericksburg,va
Should of said Hemi sorry. Your picture seems to answer the question, just thinking of that sharp edge, could ease it a little. What compression is in your pic. I’ll have a 4.5 crank so I’m thinking not to much dome for 10.1 and stock head. Maybe aluminum sometime in the future as the money comes around. Been a few days, just thought to catch up with this thread. 10.3, basically the same combination you're asking for in the parts wanted area, so this is about how much dome you will want. 4.5 stroke, std deck height, 7.100, .990. These are package number 804IN from Diamond, and I believe they are probably Indy's 572 crate engine piston although I can't prove that, and I did not buy them from Indy. You're looking at about a 73 to 75cc dome to be in the low 10s for compression like you want. The edges are all broken by cnc right out of the box, there aren't any sharp edges. It's hard to tell by the pictures though. Thanks, block is 4.53- .030 over, Hope there are pistons made for that. Looking to do aluminum caps who makes those?
[Re: cudaman1969]
#2794347
07/08/20 01:39 PM
07/08/20 01:39 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Why do you want aluminum caps on a after market Hemi block? I would use ductile iron before aluminum on a iron hemi block
[Re: Cab_Burge]
#2794392
07/08/20 03:30 PM
07/08/20 03:30 PM
cudaman1969
fredericksburg,va
Why do you want aluminum caps on a after market Hemi block? I would use ductile iron before aluminum on a iron hemi block It came with no caps, I’m open to whatever. I’ve got 3 stock caps installed so far (stock are bigger for some reason) but would like a stronger cap. I was under the impression aluminum would absorb the shock loads better? These pop up adds are getting to be a pain!!!
[Re: cudaman1969]
#2794449
07/08/20 06:27 PM
07/08/20 06:27 PM
Cab_Burge
Get the free adblocker on the 3 dots on the top right hand side of this sites web screen , Click on the settings and load it on your computer Have you check with Summit or Jegs for buying unfinished new caps in aluminum, steel and ductile iron? If not due that now If they don't offer them try calling Koffels for them at 419-433-4410
[Re: cudaman1969]
#2794478
07/08/20 07:29 PM
07/08/20 07:29 PM
Hemi_Joel
Minnesota
Why do you want aluminum caps on a after market Hemi block? I would use ductile iron before aluminum on a iron hemi block It came with no caps, I’m open to whatever. I’ve got 3 stock caps installed so far (stock are bigger for some reason) but would like a stronger cap. I was under the impression aluminum would absorb the shock loads better? These pop up adds are getting to be a pain!!! cudaman1969 there is a free browser that you can download to replace Internet Explorer or Google Chrome that totally eliminates the pop-ups and most of the ads. It is called brave. Just download it and use it and no more infostinks
[Re: Hemi_Joel]
#2794482
07/08/20 07:44 PM
07/08/20 07:44 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Tree Why do you want aluminum caps on a after market Hemi block? I would use ductile iron before aluminum on a iron hemi block It came with no caps, I’m open to whatever. I’ve got 3 stock caps installed so far (stock are bigger for some reason) but would like a stronger cap. I was under the impression aluminum would absorb the shock loads better? These pop up adds are getting to be a pain!!! cudaman1969 there is a free browser that you can download to replace Internet Explorer or Google Chrome that totally eliminates the pop-ups and most of the ads. It is called brave. Just download it and use it and no more infostinks Thankyou very much. No more infolinks!
[Re: cudaman1969]
#2794547
07/09/20 01:43 AM
07/09/20 01:43 AM
Posts: 1,229 In The Hills
jughed
In The Hills
what ads??? problem solved with adblockplus
