Good Products for Sealing Cracks in Concrete Block Walls #2789801
06/27/20 10:25 AM
06/27/20 10:25 AM
New Jersey
P
Powerflow Offline OP
P
New Jersey
We're in 'fix-up' mode because we will be selling soon. Our basement has concrete block walls and there are a number of cracks in the mortar and a few that go through the blocks themselves. I don't see any movement, just cracks. I want to do a quick patch job on the cracks and then paint the basement walls white so everything blends in. What would be the best products to use? If there is a good 'squeeze-tube' type of patch I'm all ears. Any ideas appreciated.
Re: Good Products for Sealing Cracks in Concrete Block Walls [Re: Powerflow] #2789822
06/27/20 11:20 AM
06/27/20 11:20 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
ACE hardware sells mortar in a premixed can.
Re: Good Products for Sealing Cracks in Concrete Block Walls [Re: stumpy] #2790295
06/28/20 01:06 PM
06/28/20 01:06 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
There are some vids on Youtube addressing this. I'm using the epoxy pack that Simpson[ the company that makes a lot of structure components for construction] makes for this purpose. There are other companies too. I got this off Amazon since the local stores did not carry it. Its a liquid low viscosity material that you pump into the crack using a caulking gun. The fun part for me is backstopping the fill to keep it from oozing out. I purposely did't lay on the epoxy paste like they say as my foundation has a lot of it above ground and didn't want the repair area to be see. A basement should be a breeze as its backfilled on the one side.
Carl Kessel
Re: Good Products for Sealing Cracks in Concrete Block Walls [Re: CKessel] #2790522
06/28/20 09:36 PM
06/28/20 09:36 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I've used different stuff over the years and I found that I like normal mortar the best. If the cracks are larger, I like hydraulic cement. For smaller areas, I use older plastic containers to mix the mortar and just throw it away when I've done. I'm picky so, I normally go over my work with a damp sponge and everything blends in perfectly.
Re: Good Products for Sealing Cracks in Concrete Block Walls [Re: Powerflow] #2791103
06/30/20 06:20 PM
06/30/20 06:20 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Ive used stuff from Emecole to seal up a crack in my basement concrete walls. Works well. Watched a few videos and applied the stuff. It expands and sealed up any issue I had. This doesn't "blend" in very well unless you work the stuff afterward or hide it behind a framed wall.
https://emecole.com/diy-basement-wall-crack-repair/
1972 Dodge Challenger
Re: Good Products for Sealing Cracks in Concrete Block Walls [Re: Powerflow] #2791206
06/30/20 08:54 PM
06/30/20 08:54 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
Get some sikaflex 1a
clean and dry the cracks
fill and let dry
paint
this stuff bonds well and flexes
