Venturi ID and Sizes - AVS Carb #2790894
06/30/20 07:33 AM
06/30/20 07:33 AM
Virginia
V
vadartlover Offline OP
V
Virginia
While refreshing my AVS in anticipation of starting my 440, I noticed the Venturi numbers are different. They are: 1307 & 1273.
What is the significance of the numbers?
Do they relate to sizes?
Why would they be different?
Re: Venturi ID and Sizes - AVS Carb [Re: vadartlover] #2790897
06/30/20 07:47 AM
06/30/20 07:47 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you're probably referring to the numbers on the clusters. they're numbered because they are specific to each different model number. they are lefts and rights. I think yours are mismatched.
Re: Venturi ID and Sizes - AVS Carb [Re: lewtot184] #2790965
06/30/20 12:16 PM
06/30/20 12:16 PM
VA
dragon slayer Offline
VA
1307 is from a 383 AVS 6125; You need a 1272 to go a long with your 1273 for a 1970 AVS for 440.
Re: Venturi ID and Sizes - AVS Carb [Re: dragon slayer] #2790994
06/30/20 01:32 PM
06/30/20 01:32 PM
Virginia
V
V
Virginia
thanks for the reply. any idea where to find them?
