A/C Pressures #2788531
06/23/20 04:55 PM
06/23/20 04:55 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9. 95 degree ambient temp. Hi and low temps ideally.
Grandma always said I had "hands of gold"!
Re: A/C Pressures [Re: CHRGR69] #2788804
06/24/20 12:51 PM
06/24/20 12:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
At 95 degrees I would expect to see R-12 high side pressure in the mid-to high 200's, low side 20 to 40.
Re: A/C Pressures [Re: John_Kunkel] #2788874
06/24/20 03:58 PM
06/24/20 03:58 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Sorry, its retro fitted with 134a.
Re: A/C Pressures [Re: CHRGR69] #2789353
06/26/20 08:38 AM
06/26/20 08:38 AM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
The chart I use says at 95 degrees ambient, low side 50-55 psi, high side 275-300 psi
Re: A/C Pressures [Re: tmef] #2789355
06/26/20 08:51 AM
06/26/20 08:51 AM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
This is it.
Re: A/C Pressures [Re: tmef] #2789475
06/26/20 01:15 PM
06/26/20 01:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Charts based on a dedicated R-134 system might not be relevant for conversions where the recommended charge is only 85-90% of the R-12 charge.
Re: A/C Pressures [Re: John_Kunkel] #2789709
06/26/20 10:44 PM
06/26/20 10:44 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Operating pressures are operating pressures regardless.
Re: A/C Pressures [Re: tmef] #2789791
06/27/20 09:48 AM
06/27/20 09:48 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
its easy to predict the low side pressure, but predicting the high side pressure by ambient temperature is a crapshoot, its very dependent on the generosity of the original condenser sizing, the fan type, and control strategy. We see charging charts based on ambient conditions on commercial equipment, but the chart was plotted by the OEM based on the original gas being tested in every possible temperature/humidity scenario Most of the older cars have a thermostatic expansion valve and with R-134a, I slowly add charge until I stop seeing a change in the superheat and suction pressure, that indicates its getting enough liquid to gain control. The sight glass will remain bubbling, but as the valve gains control and throttles, usually the sight glass will start to fill on its own as the interior cools down and the load decreases.
Re: A/C Pressures [Re: Uberpube] #2789887
06/27/20 02:35 PM
06/27/20 02:35 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
I don't have the high side fittings on two of my cars converted to 134 fittings because of what you say, high side has a mind of its own. I go by just touch of hand on the suction line at the compressor and monitoring the site glass. On my Rampage if the site glass goes completely clear I have over charged and can feel the temp change on the suction line. Scientific approach to A/C servicing? No, but it works for me.
Re: A/C Pressures [Re: tmef] #2789917
06/27/20 03:42 PM
06/27/20 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
So, when a dedicated R-134 system leaks off 10-15% of its charge, the pressures listed above are still attainable?
Re: A/C Pressures [Re: tmef] #2791257
06/30/20 10:17 PM
06/30/20 10:17 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I agree with the sight glass. When mine was bubbling it was actually colder than when it went clear. I thought clear was golden. Should I release (capture) some 134a so it bubbles again?
