Have you ever shorted out a starter?
#2788801
06/24/20 12:34 PM
06/24/20 12:34 PM
Posts: 1,630 North Central Florida
eightlitermopar
Quick question for all of you who are much smarter than me. I posted threads a few years back about an electrical short I was having in my Roadrunner, 383 auto with a mopar mini starter on it. The battery was disconnected. When I connected the battery, it fried wires under my dash and my main power feed wire to the ammeter. The key was not even in the car, lights were in the "off" position. My question: Could a bad starter short out and cause such wires to fry like that? The car was sitting for several years before I hauled it to our new home across the country. Maybe sitting caused something? The starter is over 20 years old and has spent most of its life close to the header pipe. Thanks in advance, Eightlitermopar For anyone bored that wants to see the original threads, here are the 2 links: https://board.moparts.org/ubbthread...in-walk-me-through-this.html#Post2642205https://board.moparts.org/ubbthread...in-walk-me-through-this.html#Post2642205
Mopar or no car
Re: Have you ever shorted out a starter?
[Re: eightlitermopar]
#2788809
06/24/20 01:01 PM
06/24/20 01:01 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would think a direct short at the starter lug would isolate any damage to the main battery cable and none under the dash.
[Re: John_Kunkel]
#2788855
06/24/20 03:09 PM
06/24/20 03:09 PM
eightlitermopar
I would think a direct short at the starter lug would isolate any damage to the main battery cable and none under the dash. Hmmm, that is kinda what I was thinking too. The main hot wire that goes under the dash is attached to that wire which is why I thought I would ask. I didn't have any problems for 20 years. This happened suddenly. Now the car sits and it's driving me crazy. I have a cheap multimeter from harbor freight, but I don't know much about finding shorted wires with it. I can't hook up the battery because the short is still present. Electrical isn't my strong point, but I'm slowly learning. I still may pull the starter and bench test it, but It's probably a light switch or something simple like that. Thanks! eight
Mopar or no car
[Re: John_Kunkel]
#2788875
06/24/20 03:59 PM
06/24/20 03:59 PM
RapidRobert
I would think a direct short at the starter lug would isolate any damage to the main battery cable and none under the dash. agreed. you might disconnect the battery positive cable & pull one fuse at a time & with the meter on ohms touch one lead to that cable & the other to ground & see if there is no longer any continuity to ground after you pull a certain fuse. Might be a start
[Re: RapidRobert]
#2788884
06/24/20 04:14 PM
06/24/20 04:14 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
Just guessing but what about a shorted alternator? I know a shorted out alternator would fry the fusible link first but what if the fusible link didn't do its job? 2 years ago I had a shorted alternator and the fusible link fried when I hooked up the battery cables to the battery.
#2788896
06/24/20 04:39 PM
06/24/20 04:39 PM
Posts: 4,961 WI
Dcuda69
WI
I would think a direct short at the starter lug would isolate any damage to the main battery cable and none under the dash. Hmmm, that is kinda what I was thinking too. The main hot wire that goes under the dash is attached to that wire which is why I thought I would ask. I didn't have any problems for 20 years. This happened suddenly. Now the car sits and it's driving me crazy. Correct me if I'm wrong but shouldn't the power feed going inside come off the starter relay not the starter itself? Pretty sure mine's a fuselink off the relay...only thing on the starter is the main batt cable and the switch wire(also coming from the relay)
[Re: 70sixpkrt]
#2788898
06/24/20 04:44 PM
06/24/20 04:44 PM
eightlitermopar
Just guessing but what about a shorted alternator? I know a shorted out alternator would fry the fusible link first but what if the fusible link didn't do its job? 2 years ago I had a shorted alternator and the fusible link fried when I hooked up the battery cables to the battery. I had the same thought. I actually changed the alternator and voltage regulator just in case 2 years ago when this drama started. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) the bug has bitten me again and I've started messing with it again. I'll figure it out eventually. My two guesses were a starter or a corroded light switch or something. I'll let everyone know if I find something. eight
Mopar or no car
#2788929
06/24/20 06:22 PM
06/24/20 06:22 PM
John_Kunkel
Rio Linda, CA
, it fried wires under my dash and my main power feed wire to the ammeter. Could be the ammeter itself. Not unheard of.
[Re: John_Kunkel]
#2788996
06/24/20 09:43 PM
06/24/20 09:43 PM
eightlitermopar
, it fried wires under my dash and my main power feed wire to the ammeter. Could be the ammeter itself. Not unheard of. Could that be tested with a multimeter? Its basically a free flowing channel of electricity isn't it?
Mopar or no car
#2789028
06/24/20 11:14 PM
06/24/20 11:14 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
, it fried wires under my dash and my main power feed wire to the ammeter. Could be the ammeter itself. Not unheard of. Could that be tested with a multimeter? Its basically a free flowing channel of electricity isn't it? As others have stated, you need to put your ohmmeter on the battery leads (no battery!!!) and start disconnecting things until the reading significantly increases (higher ohms is a more OPEN circuit.) The alternator power wire— the heavy wire on the stud, is the first thing I would disconnect.
[Re: Sixpak]
#2789200
06/25/20 04:54 PM
06/25/20 04:54 PM
eightlitermopar
I wanted to give an update for today. With lots of good advice I wanted to take the effort to update results. Not sure if I made any progress today though.
1) Replaced the starter relay. I had a spare laying around, so it went in.
2) Since I love to do things as complicated as possible, I jumped the starter directly from a fresh battery and it was VERY SLUGGISH. Did not get one single engine revolution out of it. The jumper cables were VERY warm afterwards. Pulling some amps. I fought some headers and got the starter out of the car and bench tested it. It worked great on the bench, engaged and spun fast. Put it back in the car, same slow result. When a load is placed, it’s tired. Ordered a new starter. Maybe this was the problem? I hope it’s that simple.
I cleaned up the fat wire to the starter, made sure there were no broken or melted places.
3) I did some poking around with my ammeter on the ohms setting.
I placed the one end on the POSITIVE cable side and started checking with the other. I checked the following: There was a reading on the “hot” alternator stud. I figured this was to be expected.
No readings on from the coil, positive or negative side.
I checked the park lights on the front since I was up there and resting in the shade of the car. No reading. The fuse box. See picture attached.
I got a reading on all fuses on the left side and the “battery” spot on the bottom. All light related. Is this not to be expected?
If the starter doesn’t fix this issue, then the light circuits are my next focus. They are suspect.
I’ll let you know if the new starter actually works.
Thanks again. I appreciate the patience. Eightlitermopar
![Name: fuse box.jpg
ID: 397709 fuse box.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/397709/filename/fuse box.jpg)
Mopar or no car
[Re: Sniper]
#2789345
06/26/20 07:57 AM
06/26/20 07:57 AM
Posts: 9,882 MI, usa
dvw
MI, usa
When a battery positive melts/burns it obviously has touched ground. The damage to the hot wire will only be as far as the ground source. If your dash wiring melted there are only 2 sources coming through the firewall. The black wire from the alternator output stud. And the blue fusible link from the starter relay. This wire is red on the inside of the car. If it didnt burn the fusible link the issue is in the black wire circuit.The black wire has splices feeding various items in the dash. The ignition switch, headlamp switch, horn relay, fuse block, and ammeter. Follow the melted black wire circuit under the dash until the wire isnt damaged. At that point you'll find your issue. Doug
[Re: dvw]
#2789389
06/26/20 10:29 AM
06/26/20 10:29 AM
eightlitermopar
the starter needs two things to work properly, a good, clean connection at the stud and a good clean connection to ground, this includes the negative battery cable. Did you do any voltage drop tests? I have not done a voltage drop test. I haven’t gotten that far into the process yet. I will put the new starter in since I have it ordered. You bring up a good point about the ground, I will recheck this. When a battery positive melts/burns it obviously has touched ground. The damage to the hot wire will only be as far as the ground source. If your dash wiring melted there are only 2 sources coming through the firewall. The black wire from the alternator output stud. And the blue fusible link from the starter relay. This wire is red on the inside of the car. If it didnt burn the fusible link the issue is in the black wire circuit.The black wire has splices feeding various items in the dash. The ignition switch, headlamp switch, horn relay, fuse block, and ammeter. Follow the melted black wire circuit under the dash until the wire isnt damaged. At that point you'll find your issue. Doug The positive cable did not melt, but it is a large welder feed wire that I made many years ago. It may have more ability to hold that kind of amperage if it did get overloaded? I took it out and inspected it, nothing looked too terrible there. The fuseable link burned all the insulation off but did not evaporate the copper. That wire all the way to the ammeter in the dash is what fried. The ammeter studs were not burned at all. I will find a picture from one of my previous posts. Like others have said, the ammeter is on my list of questionable possible culprits. I may just bypass it to see if that solves the problem once my starter is put back in. I’m just messing with the car on my days off here and there between work and other family duties, but I will post updates as I move along. Thanks again. Eight.
Mopar or no car
[Re: dvw]
#2789464
06/26/20 01:04 PM
06/26/20 01:04 PM
eightlitermopar
If it fried all the way to the ampmeter. And did not fry the other wire at the ampmeter ? Then the ampmeter itself was the ground path and is your issue. Remember the damage will cease after the ground point. Doug I will double check, but if my memory serves me right, it was only the wire from the starter relay. It fried the fuseable link and the wire through the firewall to the one side of the ampmeter. I hope this is all it is. eight
Mopar or no car
