4 Speed Question #2787949
06/22/20 12:52 AM
06/22/20 12:52 AM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
Hey guys I have a 78 2wd 4 speed Np435 that i was wanting to replace with A833. I know that the floor hump is required which i have..
Which a8333 with od works?
Can i use the same linkage and bell housing ?
Can i use my pedals ?
Thanks In Advance ! up
2005 Dodge 1500 Slt Hemi
2008 Chrysler PT cruiser
1984 Dodge D250
1978 Dodge D100 Adventurer
1964 Meyers Manx Dunebuggy
Re: 4 Speed Question [Re: Bzzzz] #2788093
06/22/20 01:39 PM
06/22/20 01:39 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
What engine? Some truck bellhousings have a dual bolt pattern for both the 833 and NP435.
Re: 4 Speed Question [Re: John_Kunkel] #2788317
06/23/20 12:53 AM
06/23/20 12:53 AM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
the engine is 318
1984 Dodge D250
Re: 4 Speed Question [Re: Bzzzz] #2788377
06/23/20 09:44 AM
06/23/20 09:44 AM
scratchnfotraction Offline
should be able to just swap out the trans if bell housing has both bolt patterns. check you input spline count on the 833/435 before hefting the trans in place.
should be a direct swap if you have the correct wide hump floor pan. just need to cut the hole for 833 shifter on side of hump and use the 833 shifter boot/truck shifter/rods
you will have to scratch up a slip yoke/drive shaft the correct length as the 435 had a 2 piece splined slip yoke. 727 auto and 833 share the same slip yoke size when looking.
FYI.. sometime you have a 7260 at the 435 yoke and a 7290 at the rear yoke. when I build a shaft I use the same size joint on both ends. I prefer the 7260 u-joint as it was used the most by mopar and even behind some high HP cars. makes it easy when at the parts counter looking it up.
Re: 4 Speed Question [Re: John_Kunkel] #2788760
06/24/20 10:44 AM
06/24/20 10:44 AM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
The engine is 318 with 2wd np435
1984 Dodge D250
Re: 4 Speed Question [Re: scratchnfotraction] #2788763
06/24/20 10:50 AM
06/24/20 10:50 AM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
Well I need to check to see if i have dual pattern bell housing first ! i purchased the floor hump for the A833 because of the obvious Shifter location issue..i will probably use the OD trans.. i know the bearing retainer is the larger of the two
1984 Dodge D250
