Re: Congratulations to Dave Dudek [Re: BeEtLeJuIcE !] #2787595
06/20/20 11:00 PM
06/20/20 11:00 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by Doc Fiberglass..
HOW TRICK are those exhaust manifolds ? eek
There is no stone left unturned.
Just think the term - “smoke and mirrors”.
Basically a BIG SS/AH engine on the inside looking like a street Hemi on the outside.
Re: Congratulations to Dave Dudek [Re: A727Tflite] #2787608
06/20/20 11:41 PM
06/20/20 11:41 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The exhaust manifolds are nothing special. Just extrude honed street hemi manifolds. Remember, it all has to go through mufflers and a two and a half inch exhaust system all the way back to the bumper. And the hemi exhaust manifolds are outstanding as built.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Congratulations to Dave Dudek [Re: Hemi_Joel] #2787611
06/20/20 11:58 PM
06/20/20 11:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
There is not one cheap or non trick parts involved in these cars. Nothing. Not for the usual cheap azz Mopar racer
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Congratulations to Dave Dudek [Re: pittsburghracer] #2787615
06/21/20 12:15 AM
06/21/20 12:15 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Deep pockets for sure. It's still way more impressive than a light weight pipe rack.
Re: Congratulations to Dave Dudek [Re: XXHEMI] #2787719
06/21/20 11:38 AM
06/21/20 11:38 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Any link to that run? And when he put the 'Vette on the trailer? boogie
Master, again and still
Re: Congratulations to Dave Dudek [Re: DaveRS23] #2787734
06/21/20 12:15 PM
06/21/20 12:15 PM
NY
X
XXHEMI Offline OP
XXHEMI  Offline OP
X
NY
He beat the Corvette in the final.
Agreed that a lot of money is spent doing this type of racing but the majority of the racers are hard working blue collar guys.
It took me 15 years to figure it out and who knows how much $ but a wedge was not the right motor to work with in F.A.S.T
I have no complaints I still enjoy it very much but I don't think the Max Wedge will ever see 9's. At least not with a 340 lbs driver??
Re: Congratulations to Dave Dudek [Re: XXHEMI] #2787748
06/21/20 12:57 PM
06/21/20 12:57 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Ed, have you got a Hemi in the works?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Congratulations to Dave Dudek [Re: justinp61] #2787777
06/21/20 02:15 PM
06/21/20 02:15 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
[/quote] still way more impressive than a light weight pipe rack. [/quote]
Nailed it! Congrats Dave, proving once again hard work pays off!
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: Congratulations to Dave Dudek [Re: SuperStockWagon] #2787825
06/21/20 04:09 PM
06/21/20 04:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Is the front of the hood supposed to be lifting up that much........
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Congratulations to Dave Dudek [Re: B3422W5] #2787829
06/21/20 04:31 PM
06/21/20 04:31 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
https://www.fastdrags.com/
Old pictures and chit.....
Re: Congratulations to Dave Dudek [Re: B3422W5] #2787899
06/21/20 08:50 PM
06/21/20 08:50 PM
A727Tflite Offline
A727Tflite  Offline
It’s not lifting up - old school trick to get more fresh air under the hood.
Some guys raise the rear part of the hood to let hot air escape too.
Re: Congratulations to Dave Dudek [Re: Hemi_Joel] #2787907
06/21/20 09:09 PM
06/21/20 09:09 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I'm surprised. Would have thought extensively hand ported before extrude honing at least. At best I would think cut/weld/blend so the downward break wasn't so extreme. (try to increase radius at top of manifold ports)
Re: Congratulations to Dave Dudek [Re: B3422W5] #2787909
06/21/20 09:18 PM
06/21/20 09:18 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
OG Ram Air.
'63 Dodge 330
11.19 @ 121 mph
Re: Congratulations to Dave Dudek [Re: INTMD8] #2787924
06/21/20 10:11 PM
06/21/20 10:11 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I tried that, it didn't help.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Congratulations to Dave Dudek [Re: Hemi_Joel] #2788011
06/22/20 10:04 AM
06/22/20 10:04 AM
an8sec70cuda Offline
Just awesome!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Congratulations to Dave Dudek [Re: an8sec70cuda] #2788014
06/22/20 10:09 AM
06/22/20 10:09 AM
tboomer Offline
tboomer  Offline
Wow! That's making some steam!
Re: Congratulations to Dave Dudek [Re: John Brown] #2788092
06/22/20 01:38 PM
06/22/20 01:38 PM
central il.
second 70 Offline
second 70  Offline
central il.
Hemi Joel's GTX is one of the cars pictured.
Re: Congratulations to Dave Dudek [Re: XXHEMI] #2788113
06/22/20 02:39 PM
06/22/20 02:39 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Impressive for sure. Dave's talent, both the engine and the quality of the car, is awesome.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Congratulations to Dave Dudek [Re: OhioMopar] #2788256
06/22/20 09:18 PM
06/22/20 09:18 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
I have no trick as far hood goes it lift a lot @ 120 plus mph Dave going much faster
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
