Mancini steel shims and Mr Gasket prob the same? #2787685
06/21/20 10:27 AM
06/21/20 10:27 AM
Indiana
68_661charger Offline OP
Indiana
I have Mancinis BB steel shim head gaskets and I need 1 to fix a problem I think I solved. They dont seem to be orderable right now. Are Mr Gasket 1135s probably the same thing and manufacturer?
Thanks in advance.
Re: Mancini steel shims and Mr Gasket prob the same? [Re: 68_661charger] #2787760
06/21/20 01:28 PM
06/21/20 01:28 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
SuperFormance makes them. Todd
Re: Mancini steel shims and Mr Gasket prob the same? [Re: sasquatch] #2787845
06/21/20 05:58 PM
06/21/20 05:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Greg would probably sell you just one gasket shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Mancini steel shims and Mr Gasket prob the same? [Re: fourgearsavoy] #2788266
06/22/20 09:49 PM
06/22/20 09:49 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I can't speak to any other brands, but Mr Gasket looks like the exact same steel gasket that Mopar Performance sells, but Mr Gasket puts a high temp coating on them (looks like aluminum paint). I have had both and had them side by side, right on top of one another. And you will always need to use a little extra pressure to slip it on the right side dowel pin for all of these gaskets.
Mancini is using the exact same picture on their site for the Mancini gaskets and the Mopar Performance, I'd be willing to be they are the same. The gaskets I have don't look like exactly like either though, they look exactly like the picture Mancini is using for the Superformance gasket with the larger rectangles for the cooling passages.
