car engine dies #2786148
06/16/20 09:07 PM
06/16/20 09:07 PM
olive branch ms
67llite Offline OP
67llite  Offline OP
olive branch ms
69 dart, added a/c and electric fan, and 100 amp alt. car will die at red lite if you sit to long with a/c and electric cooling fan on. feels like the car looses electrical to engine, but will restart.
Re: car engine dies [Re: 67llite] #2786163
06/16/20 10:10 PM
06/16/20 10:10 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Increase the idle speed a couple hundred rpms?
Is the Alt out put as good as it should be?
The AC tends to slow down the engine rpm, so bumping it up a bit may solve the problem.
Most high amp alternator still need to spin at a higher rpm to charge at full capacity, but maybe yours is not putting out as much as it should. I am assuming you upgraded the car wiring and the voltage regulator when you installed the 100 amp alt., if you didn't that is probably your problem. Gene
Re: car engine dies [Re: poorboy] #2786578
06/17/20 08:19 PM
06/17/20 08:19 PM
olive branch ms
67llite Offline OP
67llite  Offline OP
olive branch ms
thanks i did not upgrade the regulator
Re: car engine dies [Re: poorboy] #2786581
06/17/20 08:25 PM
06/17/20 08:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: car engine dies [Re: TJP] #2788270
06/22/20 09:50 PM
06/22/20 09:50 PM
olive branch ms
67llite Offline OP
67llite  Offline OP
olive branch ms
engine still died, until i replaced the coil, driving two days and engine still runs
Re: car engine dies [Re: 67llite] #2788378
06/23/20 09:45 AM
06/23/20 09:45 AM
Success up
Re: car engine dies [Re: 67llite] #2788403
06/23/20 10:31 AM
06/23/20 10:31 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up But you may still want to look at the wiring. The factory wiring was only rated for about 50 amps or so. Some fans by themselves can pull 40+ amps. Keep in mind there are a ton of unknown variables involved on our part beer
Re: car engine dies [Re: TJP] #2788656
06/23/20 09:51 PM
06/23/20 09:51 PM
olive branch ms
67llite Offline OP
67llite  Offline OP
olive branch ms
ok thanks guys
