lm1 users
#278652
04/05/09 08:54 PM
04/05/09 08:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
what is your A/F out of the hole? i'm in the 10s then its in the 12.5 range past the pump shot
i'm more interested in footbrake guys as i dont think transbrake guys deal with this
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: lm1 users
[Re: sixpackgut]
#278655
04/06/09 12:27 PM
04/06/09 12:27 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
Mine was 14.1 at the hit with the old fuel pump and leaned out to 15.3 at the end of the run. I switch pumps and the LM1 read 11.9 to 12.3 the whole run, which was slower than the lean runs That is using a 30 cc pump on the center carb. only and 32 squirter I am getting ready to do some more tuning on both sets of carbs as soon as I get the LM1(with the LC1 upgrade) back in the car The power cord broke the red wire solder connection going into the box
Re: lm1 users
[Re: sixpackgut]
#278658
04/06/09 12:43 PM
04/06/09 12:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Granted I run a trans brake but I see the dip as soon as I hit the pedal and it quickly goes to the level it should but it always gets the dip(this is from when its idling to WOT)... its just the pump shot
Re: lm1 users
[Re: MR_P_BODY]
#278659
04/06/09 01:20 PM
04/06/09 01:20 PM
sixpackgut
Charleston
MR P BODY, do you dip into the 10 range on the hit?
i could put smaller cams in my setup if i wanted too, i'm just curious what other guys are seeing
Re: lm1 users
[Re: sixpackgut]
#278661
04/06/09 01:49 PM
04/06/09 01:49 PM
MR_P_BODY
No I went to 11.6 most every time, sounds like your squirters are too big
Re: lm1 users
[Re: MR_P_BODY]
#278662
04/06/09 03:11 PM
04/06/09 03:11 PM
sixpackgut
Charleston
yes, i agree. thanks guys
Re: lm1 users
[Re: cudabunch]
#278665
04/06/09 03:37 PM
04/06/09 03:37 PM
sixpackgut
Charleston
it dips into the 10 when i mash the pedal. i have been testing in DaScreet.
a smaller shooter will change the duration of the pump shot but not lessin it.
Re: lm1 users
[Re: sixpackgut]
#278667
04/06/09 04:41 PM
04/06/09 04:41 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
DaSecreet huh, I had Dan order me a 3-X manifold just to stay ahead.
