Re: Garage Door Painting Help Needed
[Re: vinnyd76]
#2786342
06/17/20 12:13 PM
06/17/20 12:13 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Maybe related, I always wondered, if you paint an installed door in a closed position, does it want stick to together, and not want open when the paint is dry? And the solution is?
[Re: jcc]
#2786667
06/18/20 05:57 AM
06/18/20 05:57 AM
Posts: 5,651 Port Huron, Michigan
MI_Custumz
Spent hours doing our old garage door before the wife wanted to change it to a newer design. It was the one with the 5 or 6 shorter rectangle insets (or whatever they are called). It did have some texture to it, but not much. I sanded, TSP wipe, and then used a quality outdoor primer and paint. To keep it from drying I painted the top section first and got into the crack a bit and painted the second section. When I was close to the joint, I would roll the door up a bit so the joint was open. I did it in 2 days. Top 2 panels one day and bottom 2 the next day. Did it in the summer so it would dry pretty much that day. It did stick a tad, but not enough to keep the door from opening. If I were to do it again, I would let it dry for a few days before moving it again. Didn't want to leave the door open all night when I painted it.
[Re: jcc]
#2786859
06/18/20 03:17 PM
06/18/20 03:17 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Maybe related, I always wondered, if you paint an installed door in a closed position, does it want stick to together, and not want open when the paint is dry? And the solution is? I paint a few of the sections cracked open. Paint dries fast in.the heat here. Then dp.the rest. As I am able to get Inside the sections whole open. It was white before and now a light tan.. I used a brush in the cracks and a small 6 inch roller on the sections it was good quality paint from Val Spar (PPG) Custom mixed to.matcj the vinyl siding on my home
[Re: burdar]
#2786958
06/18/20 09:08 PM
06/18/20 09:08 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
Does the door have an embossed wood grain print in the metal panels? Yes, the metal garage door has the grain texture. It also has the individual squares as depicted in the photo below. There has to be roughly 4-layers of paint on the door. Some people have recommended thinner or an 80-grit sand paper.
[Re: vinnyd76]
#2787153
06/19/20 03:15 PM
06/19/20 03:15 PM
Posts: 108 Ohio
ChallengerTA
Ohio
If its been painted a few times you will always have trouble with it lifting. I completely stripped mine to bare metal using a chemical stripper. Was pretty easy to scrap the paint off. Used a good metal prep primer (Galvinized) and followed that with the Behr Paint and Primer in one offered by Home Depot and its been on for the past 10 years with no signs of lifting or peeling and still looks like brand new.
Jason 1970 Challenger T/A
