Anybody Use the Eastwood Paintless Dent Removal Kit #2786139
06/16/20 08:28 PM
06/16/20 08:28 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
https://www.eastwood.com/eastwood-paintless-dent-removal-kit.html
Has anyone used this? I am thinking of getting it for door a dent on a Crown Vic ex-police car that's my daily driver. Or I could save the $50 and live with the dent...
Thanks.
Greg
Re: Anybody Use the Eastwood Paintless Dent Removal Kit [Re: GregY] #2787946
06/22/20 12:27 AM
06/22/20 12:27 AM
IMGTX Offline
IMGTX  Offline
There are several things to consider.
Older thicker metal cars do not do well with glue on or many of the paint less systems because the metal is not as soft. I have straitened a taillight enclosure on a late model Pontiac bare handed. Not gonna happen with a Dart or Cuda.
The location of a dent has a lot to do with the process to remove it. Flat or curved panel? Middle of panel is different than edge of panel or along a ridged body line.
Paint condition also effects the glue type pullers.
Do you have a picture?
What year crown vic?
Being in the door you may be able to reach it from inside and press it out with a piece of wood or hammer handle.
If the car is anything older than a 1998-ish I would roll the dice and get the kit. Eastwood is pretty good for most stuff and late model stuff bends like butter.
Re: Anybody Use the Eastwood Paintless Dent Removal Kit [Re: IMGTX] #2787984
06/22/20 08:29 AM
06/22/20 08:29 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Its a 2009. Its a somewhat shallow dent in the middle of the rear door, and passes through a body line. It seems like the paint is an issue on that era Crown Vic, I am a little worried about the glue lifting the paint off.
I may try and pull the inside door panel and see what I can do to push it out from the inside.
Re: Anybody Use the Eastwood Paintless Dent Removal Kit [Re: GregY] #2788304
06/22/20 11:49 PM
06/22/20 11:49 PM
5thAve Offline
5thAve  Offline
They're useless. Spend some more dough and get PDR done on it.
With a Crown vic you also risk pulling the paint off with it especially if it's white or a lighter color.
