440 intake curiousity #2785712
06/15/20 01:29 PM
06/15/20 01:29 PM
Colleyville
3hundred Offline OP
3hundred  Offline OP
Colleyville
Years ago I had a CH4B that had the center divider cut down about 1" from the carb flange. Was wondering on a stock 440 what would be the effect of cutting down that divider about 1" ?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 440 intake curiousity [Re: 3hundred] #2785713
06/15/20 01:33 PM
06/15/20 01:33 PM
Do it and find out sawzall work
Re: 440 intake curiousity [Re: 3hundred] #2785748
06/15/20 02:55 PM
06/15/20 02:55 PM
AndyF Offline
AndyF  Offline
You probably won't be able to notice the difference
Re: 440 intake curiousity [Re: AndyF] #2785749
06/15/20 03:06 PM
06/15/20 03:06 PM
Colleyville
3hundred Offline OP
3hundred  Offline OP
Colleyville
Okay, backstory, I was told the modded CH4B was on a 505 stroker w/ a 750 CFM carb. Supposedly the mod was to make the engine perceive the carburetor was bigger? shruggy
I've been toying with the long term idea (probably never happen) of a sniper fuel system thinking the mod would eliminate the dual plane problem with FI. In the meantime I was just curious what it would do with the stock carburetor.
'69 300 Convertible
'16 300 S Hemi
Re: 440 intake curiousity [Re: 3hundred] #2785754
06/15/20 03:21 PM
06/15/20 03:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Only one way to know for sure exactly what it would do on your combo.
The good news is, if for some reason it’s not to your liking....... it’s not that hard or expensive to find a replacement.
Re: 440 intake curiousity [Re: 3hundred] #2785851
06/15/20 08:42 PM
06/15/20 08:42 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If the intake is limiting power output of a motor that has additional potential, then milling the divider will likely add peak power, and may, or may not impact lower rpm power.
Re: 440 intake curiousity [Re: 3hundred] #2785863
06/15/20 09:56 PM
06/15/20 09:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A 1" open spacer (if it fits your hood, linkage, fuel line, etc.) has a similar effect.
Expect:
1. idle quality suffers slightly, idle vacuum lower
2. response may need more pump shot
3. mileage may go either way
4. peak power increased slightly (most if plenum and/or carb is small)
5. cylinder to cylinder distribution may get worse (on a well-developed manifold)
Boffin Emeritus
Re: 440 intake curiousity [Re: 3hundred] #2785968
06/16/20 10:57 AM
06/16/20 10:57 AM
Minn
SportF Offline
SportF  Offline
Minn
Years ago (maybe like 50) I had a factory 4 hole 383 manifold that I made into one big square hole. All blended and looking great. I thought it was working until I put on my two barrel manifold for winter driving. The two barrel was such a marked improvement in performance it was rather unbelievable.
My mechanic neighbor said something to the effect "did you think the factory guys were stupid?"
My only reply was to toss the manifold.
