will an 03 timing cover/accessory drive bolt up to an eagle?
#2785625
06/15/20 10:19 AM
06/15/20 10:19 AM
Posts: 2,256 IL
furious70
IL
The early truck timing cover/accessory drive with the radiator hose going to the dr's side could help me package the turbo on the pass side - is it interchangeable with both car and truck eagle engines?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: will an 03 timing cover/accessory drive bolt up to an eagle?
[Re: furious70]
#2785643
06/15/20 11:00 AM
06/15/20 11:00 AM
Posts: 2,256 IL
furious70
IL
and/or does that early waterpump interchange with the later cover aside from any belt interference to deal with?
[Re: furious70]
#2785655
06/15/20 11:29 AM
06/15/20 11:29 AM
Posts: 1,113 Usa
A39Coronet
Usa
and/or does that early waterpump interchange with the later cover aside from any belt interference to deal with? Early waterpump won't work with later timing cover because early pump impeller protrudes beyond the pump gasket face. It relies on the timing cover for clearance.
[Re: A39Coronet]
#2785663
06/15/20 11:50 AM
06/15/20 11:50 AM
Posts: 2,256 IL
furious70
IL
I'm wondering about interference to VVT cam sprocket now with early cover.
